Date/Time: Thu, 03 Apr 2025 01:10:35 +0000
real time data
View Count: 345
[2022-12-20 14:31:59]
colonwing1888 - Posts: 26
1 ) I cannot get the real time data for cfd ( e.g. AUDCAD ) even though I have set the current selected service to scdata-all service !
2) I want to change the time zone to Hong Kong. I have set to - gobal setting - time zone setting - Value ( hong kong 9 +8HKT ) . However, It cannot change to hong kong time zone!
Please advise how to fix
[2022-12-20 16:28:22]
John - SC Support - Posts: 39122
With regards to the Time Zone, are you unable to change the Global Time Zone for some reason? Is it not staying as Hong Kong? Each chart also has a setting for the Time Zone, which would normally be set to use the Global Time Zone, but if your charts are not changing after changing the Global Time Zone then you would need to check each chart to ensure it is set to use the Global Time Zone (or is using a Time Zone you want). Refer to the following:
Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu)
With regards to the data - follow these instructions to get us your Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
