Date/Time: Thu, 02 May 2024 08:59:08 +0000
MB Trading
View Count: 1848
[2013-03-22 17:25:18] |
GCAdmin - Posts: 35 |
What data feed would I use to get a live Futures feed from MB Trading? |
[2013-03-22 17:28:28] |
This is not supported.
[2013-05-18 23:34:11] |
If you want to see support for MB Trading, then please contact them and refer them over to this page: https://www.sierrachart.com/index.php?l=doc/doc_GeneralDataTradeServiceProtocol.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-18 23:34:30
