Date/Time: Thu, 03 Apr 2025 00:31:11 +0000
[Programming Help] - Run code when DLLs are released?
View Count: 425
[2022-12-17 20:13:09] |
ycomp - Posts: 322 |
Hello, I would like to run some code when the dlls get released, if you tell sierra to release the dlls. I tried DllMain but that didn't work for me. Do you have any sugggestions? I need to stop a thread of mine from running. sc.LastCallToFunction() will execute when I close a chartbook, so that's good.. but I'm often testing and need to stop the dlls. |
[2022-12-17 21:15:27] |
User431178 - Posts: 632 |
sc.LastCallToFunction is also true when dlls are released.
[2022-12-17 23:43:54] |
are you 100% sure about that? because I had a breakpoint set and it only activated when I closed the chartbook, not when I had the chartbook still open and I disabled dlls.. I tested both of those ways on "fresh" instances but also what version do you use? I'm only on 2400. now my code is a bit involved so there is a chance that I'm wrong about this. I'll have to test it further tomorrow. But that is good to hear that it should work. I was going to make a workaround like have a heartbeat that if it wasn't received would exit the thread. |
[2022-12-18 08:29:55] |
yes you are right, thanks! I guess something else is going on here
