Date/Time: Tue, 01 Apr 2025 22:04:43 +0000
Could NOT Load more than 120 days in 5 minute charts
View Count: 301
[2022-12-14 20:07:16]
User687917 - Posts: 75
I've been trying to get a chartbook with 5 minute chart for REPLAYS with all data from 2020 to now. But I've not been able to load more than 120-180 days on chart
Chart only has price in HLC bars and volume study
I'm using SC pack 10 with Denali (CQG order routing only from AMP Futures)
In Data/Trade Service Settings i've selected :
- Current Selected Service = CQG WebApi [Trading]
Intraday Data Storage Time Unit = 1 Tick
- Non-Tick data = 1095
- 1-Tick data = 1095
- Allow Support for Sierra Chart Data Feeds = YES
In chart Settings :
Continuous Contract (List) = Continuous Futures Contract - Volume Based Rollover
Chart Type = Intraday ( 5 minute )
Data Limiting
Date Range and Limiting Method >> Date Range in File From / To
Chart Data Type = Intraday Chart
Load Data limiting Method = Use Number of Days To Load
Days to Load for Intraday Chart Data Type = 2020-01-01
Days to Load for Historical Chart Data Type = 2022-12-14
Since I was forced to switch to Denali and SC pack 10, the loading of charts has become much slower (for the 4 charts I already had of 5 minutes (10 days of loading) and 4 historical charts on a daily basis.
And according to your support, Denali was much better than CQG ... but it doesn't seem so to me.
[2022-12-14 20:16:23]
Sierra_Chart Engineering - Posts: 19040
You need to set this setting to 1100:
Do not use a date.
If there still is missing data, then follow the instructions here:
There is a reason for this:
It is explained in the last paragraph in this subsection:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.12 - Intraday Data Storage Time Unit. Historical Data Record Time Frame.
In the case of CQG historical data (provided by CQG), since Sierra Chart has only supported 1 minute data, or limited amount of tick by tick data from CQG, this is why when using CQG data, charts will load faster. Since there is less, a lot less, tick by tick data. You can solve this problem by using an Intraday Data Storage Time Unit of 1 Second or 2 Seconds or higher.
