Date/Time: Thu, 03 Apr 2025 01:10:35 +0000
Problem with chartbooks and symbol translation (between SC Data and TETON)
View Count: 481
[2022-12-13 09:09:36]
lukaszcz - Posts: 3
Friend of mine is sharing his chartbooks with me(ie ES, CL) - created and used for SC Data service.
I am using TETON CME Order routing service and have problem with his chartbooks after opening in Sierra - data are not loaded and there is no question/detection of symbol translation.
As workaround I have to switch service to SC data and then back to TETON - in this case sierra is able to detect and do proper symbol translation.
Would it be possible to fix/solve this problem and avoid workaround with additional jumping between services? Additional effort of handling multiple chartbooks all the time.
More screenshots in chartbook_symbol_translation_issue.docx
Date Time Of Last Edit: 2022-12-13 09:10:27
Private File
[2022-12-13 15:21:41]
Sierra_Chart Engineering - Posts: 19049
Did you translate the symbols with this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
[2022-12-20 13:24:20]
lukaszcz - Posts: 3
No, missed this option before and my workaround was to switch service to trigger translation - thanks.
Have 1 more problem related to symbol translation - after translation, all details about split/merge TPO profiles are gone. Is there any option to avoid that after translation?
Date Time Of Last Edit: 2022-12-20 13:25:34
imagesymbol_translation_problem.png / V - Attached On 2022-12-20 13:23:31 UTC - Size: 30.94 KB - 109 views
[2022-12-20 15:25:47]
No this cannot be avoided:
[2022-12-20 19:52:38]
lukaszcz - Posts: 3
Will it be fixed in the future?
[2022-12-20 21:17:42]
No there are no plans for this.
