Date/Time: Mon, 31 Mar 2025 08:45:30 +0000
importe unos chartsbooks y los graficos estan vacios
View Count: 348
[2022-12-08 22:48:39] |
juan biscione - Posts: 1 |
Un compañero me envió unos chatbook, los descargue y los coloque dentro de sierra chart. Lo descargado esta dentro de open chatbook y cuando lo abro no muestra nada. Dentro hay hedmap, profail,foodprint, track levels y mas cosas. Quizás sea por mi tipo de cuenta?. Si es así por favor díganme cual es el plan que debo comprar y lo compro. Desde ya muchas gracias, un cordial saludo. |
[2022-12-08 23:04:41] |
John - SC Support - Posts: 39026 |
From Google Translate: A colleague sent me some chatbooks, I downloaded them and placed them inside sierra chart. The downloaded is inside open chatbook and when I open it it doesn't show anything. Inside there are hedmap, profail, foodprint, track levels and more.
Maybe it's because of my type of account? If so, please tell me which plan I should buy and I'll buy it. Thank you very much in advance, best regards. You are on a trial, which gives you the full access to the system, so this is not the problem. The most likely issue is simply that your friend is using a different "Service" than you are, in which case the symbols are different. To resolve this, open the chartbooks and select Edit >> Translate Symbols to Current Service. You should be fine after that. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
