Date/Time: Mon, 31 Mar 2025 05:16:01 +0000
Targets
View Count: 511
[2022-12-06 17:37:15] |
joew - Posts: 83 |
I am using 2 Targets and Common Stop with Move to Breakeven on First Target. I must have adjusted something in the settings. When my first target is hit it is closing both orders. It has been working well until today. I do not know why this changed.
[2022-12-06 19:32:28] |
John - SC Support - Posts: 39026 |
The main thing to look at is the Quantities. Make sure the quantity for the first target is not the full amount (i.e. a total quantity of 2 for the parent and a quantity of 2 for the first target is wrong). Another item to check is that the Move to BreakEven is not closing the position by moving the Stop too close to the current price. Be aware of the Move to BreakEven Offset - refer to the following: Basic Trading and the Trade Window: Set >> Move to BE Offset For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-06 19:47:29] |
joew - Posts: 83 |
No I'm not stopping myself out and I have not changed the quantity. I did disable trading from the dom and I am wondering if there is a setting or something I may have inadvertantly turned on or off that could be the issue.
[2022-12-06 20:32:14] |
Nothing off hand that would do that. You really need to look at the orders and the fills and see what caused them. The information is in the Trade Activity Log and will give you the information on exactly what happened.
