Date/Time: Tue, 01 Apr 2025 22:05:47 +0000
[Locked] - Freeze in Denali on new lows just now in ES Futures.
View Count: 1579
[2022-12-07 14:35:59]
Sierra_Chart Engineering - Posts: 19040
We are aware of the problem this morning and we disconnected users from the affected server processes. The cause of this this incident this morning was different.
This only affected some users. Not all.
Date Time Of Last Edit: 2022-12-07 14:36:16
[2022-12-07 14:36:04]
User450950 - Posts: 9
Frozen today again... right at the open for
[2022-12-07 14:37:14]
Refer to post 25 above.
[2022-12-07 15:37:17]
For an explanation of the incident from this morning, refer to:
Important Notice: Denali Data Feed Infrastructure Updates
[2022-12-07 16:04:35]
seandunaway - Posts: 348
I felt it too but really I just wanted to say thank you, we really appreciate the transparency and updates and all the efforts you're making to continually improve. I know it's not an easy task!
[2022-12-07 17:04:49]
USER0007 - Posts: 22
Thanks for the update. Does that mean we shouldn't trade until end of December until this is fixed ? I am not comfortable being in a trade and platform freezes on me.
Date Time Of Last Edit: 2022-12-07 17:06:20
[2022-12-07 17:08:11]
No this is definitely not the case:
You can certainly trade. We are completing what we need to this evening to resolve this.
Date Time Of Last Edit: 2022-12-07 17:09:15
[2022-12-09 13:33:36]
User597559 - Posts: 3
Frozen again, multiple people in my group
[2022-12-09 13:35:42]
User215984 - Posts: 24
FYI- Data just froze again at 8:30est
[2022-12-09 13:41:11]
d9e5c763 - Posts: 111
today’s ppi time is about to pause for less than 5 seconds, and the delay data of the log is immediately returned to the normal range(in the past, I may need to disconnect and connect to return to normal), but because this data is update about 5(?) seconds, there is no way to know more accurately.
I uploaded today's log file and removed the "Heartbeat" information line, amd I was testing my proxy network earlier today (not at the time period of ppi), so there are many noise in the log
Date Time Of Last Edit: 2022-12-09 14:03:08
Private File
[2022-12-09 13:53:10]
We need to see your Message Log to see what server this occurred on. Instructions:
Based upon a quick analysis we saw no issue on our side at that time. The Internet bandwidth being used was nowhere even close to what we have available.
Date Time Of Last Edit: 2022-12-09 14:02:48
[2022-12-09 14:08:19]
The log in post #34 is from someone in Hong Kong . We can clearly tell from the log that you have Internet connectivity issues. That is abundantly clear. We need to make it clear that is not an issue on the Sierra Chart side.This is from your log:
Teton CME Order Routing | There has been no activity on the network socket for 1m 11s. Will reconnect. | 2022-12-09 01:10:12.729
This is not an issue on the Sierra Chart side at all. You had a connectivity issue at that time and that is 100% definite. We also have a connection to the Teton server. And we did not lose it at that time or any time today.
And this goes to the fundamental problem of why we do not like to to explain the work that we are doing because inevitably people associate that with their issues and think there is something wrong on the Sierra Chart side when there is not.
Our conclusion at this point is for users who had a problem this morning at 8:30 AM US Eastern time, in some cases that was on your side.
Date Time Of Last Edit: 2022-12-09 14:09:09
[2022-12-09 14:15:03]
We also want to update this thread, that the issue on December 7 at 9:30 AM US Eastern time, on one server, was not the result of too many users like we had originally concluded. It was a result of a system performance issue. Which we think we have addressed either fully or partially. If it is only partially addressed, it will be fully addressed, with some additional work we will do on that system. But it definitely was an operating system level issue.
[2022-12-09 14:18:14]
I have explained the situation in the edited post. At the time you pointed out, I was changing my ISP provider. During the time of ppi(8:30 ET), I also monitored ds23. The packet loss rate has always remained 0, but I am not sure if I can always monitored this address
Date Time Of Last Edit: 2022-12-09 14:19:56
[2022-12-09 14:21:33]
User431178 - Posts: 632
It wasn't velocity logic event then, after the PPI today?
[2022-12-09 14:27:10]
We are going to monitor the activity at 9:30 AM US Eastern time at the open on the particular server that had a problem on December 7. And we will check bandwidth usage both from the CME, and our outbound Internet bandwidth and make a comparison to today at 8:30 AM Eastern.
We will see what happens.
[2022-12-09 14:32:51]
there is another situation that I must explain
because you allow three different "connections"
the instance I set to "1 minute", there was no delay.
that paused was the 1 tick instance, and the log I attached also belongs to the "1 tick" one
the "1 tick" cpu usage is always below 25%
Date Time Of Last Edit: 2022-12-09 14:34:41
[2022-12-09 14:34:59]
On one server we did briefly notice one time a 1 to 2 second lag at the 9:30 a.m. US Eastern time open for CME futures this morning at 2022-12-09. Hard for us to identify where exactly that occurred.
But the bandwidth usage, was multiple times higher as compared to 8:30 AM US Eastern time.
Whatever occurred earlier at 8:30 AM US Eastern time, was very unlikely to be an issue on the Denali side.
Date Time Of Last Edit: 2022-12-09 14:36:14
[2022-12-09 14:43:16]
This includes the complete log of heartbeat data
at 8: 30 that show the delay of 2.5 seconds
9: 30ET does not delay the fact.
Date Time Of Last Edit: 2022-12-09 15:35:41
Private File
Private File
[2022-12-09 14:44:21]
Attached is the video of what had occurred this morning on one of our servers (DS26).
If that slight momentary delay was an issue in our real-time server program it is going to be addressed, at the end of December. If the issue was an operating system level performance issue that will be addressed, as well.
If it is Internet connectivity related, which we saw no indication of this morning, we are addressing that this Friday evening and we will update the thread about that.
Private File
[2022-12-09 14:44:34]
Regarding the log at post #43 we will check that.
[2022-12-13 14:09:57]
User128517 - Posts: 10
today... around news release.. ES appeared to be fine.. NQ was not. Data was not coming through at all. Could see ES tape populating with data but not NQ. both charts were side by side.
[2022-12-13 14:28:50]
today's cpi time sierrachats did not have a delayed for me (the heartbeat log does not appear more than 1 second line)
i think the issue should be solved
[2022-12-13 14:55:35]
Confirming there was definitely not any pause or lag with the Denali data feed at the CPI Number at 8:30 AM. We did notice a lag for a few seconds at 9:30 AM open today. That was on one server. That will be addressed with our real-time server performance/architecture improvements to more fully utilize the available processing time of the server.
There could have not been an issue just with this one symbol which would have been with the Denali data feed:
The issue must have been something else, therefore, refer to:
Date Time Of Last Edit: 2022-12-13 14:56:03
