Date/Time: Fri, 28 Mar 2025 12:46:13 +0000
Stop orders all default to stop limit
View Count: 483
[2022-11-29 20:12:52] |
User911178 - Posts: 2 |
Subject updated from 'Sierra Chart Questions' to 'Stop orders all default to stop limit' -------------------------------------------------------------------------------- I placed my first order live, and all my entry orders for a Stop order default to Stop Limit. I have gone through Trade Settings, Dom Settings, Trade Window M - Orders- and there is no check mark my Stop Limit Orders. I have read up as much as i can find and find nothing. I got lots of slippage on my first order as it was a Stop Limit rather than a Stop... Then the Stop Loss order which was a Stop order on placing the order, defaulted to a Stop Limit order on the fill.. So now my stop loss is a Stop Limit which is very dangerous going into the overnight session....Need this resolved ASAP.... thank you.. |
[2022-11-29 20:17:12] |
Sierra_Chart Engineering - Posts: 18974 |
Refer to: Order Types: Stop Orders on the CME A Stop-Limit order does not result in more slippage than a Stop order. It would be potentially the opposite. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
