Date/Time: Thu, 19 Sep 2024 21:34:25 +0000
Color EMA Based on Above/Below Price
View Count: 1920
[2014-05-27 14:10:27] |
infpz - Posts: 826 |
Is this possible? Function would be similar to the Color Bar Based on Study, but I want to color the EMA, not the bar.
[2014-05-28 08:44:00] |
This can be done with the Color Bar Based on Alert Condition Study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245 The documentation explains how to color a Subgraph of another study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-30 15:26:03] |
OK. this is working, but what I'm looking to do is have the EMA colored when the market is above the EMA, and a different color when it's below. It appears that this function colors then entire EMA, when I want the color vary depending on where the market is, kind of how the line looks like when you have color bar based no slope selected in subgraphs.
[2014-05-31 01:07:24] |
vegasfoster - Posts: 444 |
You have to use two, assuming ema is ID1 and first color bar is ID2, enter alert formula the first color bar study as =C>ID1.SG1 and set the second color bar study as =ID2.SG1=0
