Date/Time: Fri, 21 Mar 2025 08:00:06 +0000
Graph Minutes Settings
View Count: 317
[2022-11-17 15:55:52]
User101919 - Posts: 27
Hello guys,
according to the title: The time in my graph somehow is not true. I don't know why.
I tried to restart graphs and reset the settings. tried to check simulator vs real trade and both are same.
the settings are 15 minute, but the time its like 10 minutes earlier (Like if New York Time Zone actually is 11:25 AM, so the graphs are showing 11:10 AM. I just see every 1- minutes candle changed.
I think its time settings but I changed from Global Zone to New York and its the same.
What is the issue? Will be glad for help.
Thank you very much.
Date Time Of Last Edit: 2022-11-18 06:07:48
imageFAILCLOCK.png / V - Attached On 2022-11-17 15:55:07 UTC - Size: 42.89 KB - 90 views
[2022-11-17 18:16:25]
John - SC Support - Posts: 38835
The time you are pointing to will show the time of the current candle, or, when the chart is showing the most recent candle, it will show the current chart time.
If you want to use this to show that your candles are every 10 minutes, then we would need to see two screenshots, one with the chart pulled back to a previously closed bar and then another screenshot with the chart moved forward by 1 bar from where the previous screenshot was taken.
Or, it would be a lot easier to turn on the horizontal time scale so we can see the times of the bars.
