Date/Time: Fri, 21 Mar 2025 07:15:48 +0000
BId x Ask Order Flow Template
View Count: 553
[2022-11-17 15:15:10]
User120955 - Posts: 7
I need assistance with getting my order flow template to show up, it was previously showing until I went to try too zoom out the screen and now it's not showing up anymore.
[2022-11-17 18:04:29]
John - SC Support - Posts: 38835
First thing is to select Tools >> Cancel Zoom In to ensure you are not zoomed into a blank portion of the chart.
If the option for Cancel Zoom In is not available, then you are no longer zoomed into that chart. In which case, you need to reset the scales. First make sure the scales are set to Automatic and then reset them. Refer to the following sections of the documentation:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
Chart Scale and Scale Adjusting: Resetting the Scale
If you still have trouble after the above, then get us a screenshot of what you are seeing so we can understand what is happening. Refer to the following for how to get us a screenshot:
