Date/Time: Tue, 26 Nov 2024 15:42:11 +0000
per previous connection issue request
View Count: 989
[2014-05-22 18:02:01]
User43219 - Posts: 2
Software version: 1137 | 2014-05-22 12:14:55
Usage end date: 2014-06-05 | 2014-05-22 12:14:55
Enabled for: Advanced Features. | 2014-05-22 12:14:55
Enabled for: Advanced Features 2. | 2014-05-22 12:14:55
Enabled for: Sierra Chart Historical Data Service. | 2014-05-22 12:14:55
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-05-22 12:14:55
Active service: CTS T4 FIX | 2014-05-22 12:14:55
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-05-22 12:14:55
2014-05-22 12:14:55 Local computer clock time | 2014-05-22 12:14:55
2014-05-22 16:14:55 GMT time | 2014-05-22 12:14:55
2014-05-22 12:14:55 Time zone adjusted time | 2014-05-22 12:14:55
Time difference to server time: 9 seconds. | 2014-05-22 12:14:55
Program path: C:\SierraChart\ | 2014-05-22 12:14:55
Data Files path: C:\SierraChart\Data\ | 2014-05-22 12:14:55
OS Version Number: 6.1 | 2014-05-22 12:14:55
Checking for new symbol settings for cts | 2014-05-22 12:14:55
Symbol settings are up-to-date for cts | 2014-05-22 12:14:55
CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2014-05-22 12:15:00
CTS FIX - Firm: KCG | 2014-05-22 12:15:00
Resolved address fix.t4login.com to IP 69.44.110.106 | 2014-05-22 12:15:00
The network socket is connected. | 2014-05-22 12:15:00
Starting SSL connection on the socket. | 2014-05-22 12:15:00
SSL socket is connected. | 2014-05-22 12:15:00
CTS FIX: Sending the Logon message. | 2014-05-22 12:15:01
CTS FIX: Received a Logout message. Text = User does not have permission to access this application | 2014-05-22 12:15:01
CTS FIX: Contact your clearing firm and have them add the Sierra Chart application to your CTS T4 username. | 2014-05-22 12:15:01
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-05-22 12:15:01
SSL shutdown indicates not able to send 'close notify'. | 2014-05-22 12:15:01
The SSL socket was shut down. | 2014-05-22 12:15:01
The SSL socket object has been freed. SSL state is now disconnected. | 2014-05-22 12:15:01
Socket has been shutdown and closed. | 2014-05-22 12:15:01
CTS FIX: Logged out and disconnected. | 2014-05-22 12:15:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-05-22 12:15:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-05-22 12:15:01
CTS FIX: Disconnected. | 2014-05-22 12:15:01
Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-05-22 12:15:01
Date Time Of Last Edit: 2014-05-22 18:07:55
[2014-05-22 18:07:34]
These are the relevant messages:
So contact your clearing firm and have them add the Sierra Chart application/program to your CTS T4 username.
