Date/Time: Tue, 04 Nov 2025 12:18:41 +0000
Can't seem to get realtime data.
View Count: 432
|   [2022-11-01 16:07:56]     |
| User582534 - Posts: 4 |
                I tried the update steps, but not working.  My funded live account is with Infinity Futures which I believe is Transact. It was working for two months, but stopped today.  |
|   [2022-11-01 17:42:53]     |
| John - SC Support - Posts: 42737 |
                TransAct/Infinity stopped support for Sierra Chart several months ago. You were able to continue to get real-time data since your non-professional verification date was October 31, 2022. Which also means that as of today (November 1) you no longer have the non-professional verification and that is why you are getting the delayed streaming data instead of real-time data. If you want to continue to use Sierra Chart for trading, then we recommend changing brokers to a broker that supports our Teton Order Routing Service. You will find the list of brokers at step #2 of the Setup Instructions, which can be found at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions If you want to continue to use Sierra Chart for charting, then you will still need to have a live, funded, futures trading account for verification of your non-professional status to get data from our Denali feed for the CME Group data. To do this, we recommend the service outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
