Date/Time: Tue, 26 Nov 2024 18:36:21 +0000
Time Range Highlight
View Count: 2048
[2014-05-22 10:49:45]
User79347 - Posts: 23
Hello!
I am using this with Reversal Bar Type and LINE ON CLOSE chart type.
But i need to coloring by Time Zones (Europa - Green, usa - blue etc etc etc)
everything is ok, before TIme Range Highlignt: if in one screen will be 2 days or more, i will have lines, which starting at the end of some time zone and ending at the start of this timezone but next day. With BAR, Candles (not Line on Close (Open too) - fully OK! But i line Line on Close with Reversal Bar Type, but lines connecting a end and start time zone at next day is terrible
is it possible to have a solution for it?
THANK YOU!
[2014-05-22 16:39:48]
We are not understanding this.
We are not sure what more we could do with the study though. Provide an image of the chart showing what you are describing:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-05-22 18:33:37]
I am very sorry for my english ;(
Here - is a screenshots:
http://enten.netne.net/ReversalBar-Line-On-Close-TimeRange_Bug.png
[2014-05-23 03:55:01]
Not sure this would help, but set the Draw Style for the Time Range Highlight study to " Line-Skip Zeros".
[2014-05-23 05:21:49]
With Draw Style - Line-Skip Zeros - the colors is absenting, only initial chart color - without colorisation..
http://enten.netne.net/With_Line_Skip_Zeros.png
[2014-05-23 06:24:31]
This will be solved in the next release, 1142.
[2014-05-23 06:46:50]
Thank you very much!
[2014-06-02 06:44:29]
Hello, as i know - in 1143 this problem still exist ;((
[2014-06-04 19:21:23]
It did work properly for us, can you post an image of what you currently see:
[2014-06-05 06:01:10]
I am affraid, i STILL have same issue ;((
http://enten.netne.net/f1.png
http://enten.netne.net/f2.png
[2014-06-05 07:10:31]
Set the Draw Style for the Subgraph of the Time Range Highlight study to Line-Skip Zeros. This will solve the problem.
Date Time Of Last Edit: 2014-06-05 07:11:11
[2014-06-05 07:22:45]
Sorry, but result is... something terrible ;)
http://enten.netne.net/f3.png
http://enten.netne.net/f4.png
[2014-06-05 07:44:14]
Not to worry. You just need to set the Scale Range for the Time Range Highlight study to "Automatic". Here are the instructions:
http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ScaleWindowStudy
[2014-06-05 09:18:18]
Hello! THANK YOU VERY MUCH! It's working!
Sorry, i am understand, it's not my business, but i wish to say something.
For a years, i use same chart type as Reversal Bar. I was very surprized, that is already realised in some of platforms ;) With Line-On-Close mode and colorisation by sessions it's almost my "own" chart. But not exactly same. If i am understand right, the difference is in absenting of "close" at my chart. I have only H and L, which forming as extremum from initial tick rows... For small pip sizes, the differences is not too big, but it's increasing with increasing of pips size. For 10 pips size, extremums from "line on close" and my chart has a differences for a several pips already. Of course my type of chart do not losing extremums, this is exactly right values, but line-on-close - losing, becouse it's closes, but not low or high.
http://enten.netne.net/comparing.png
By link - the same periods of your chart and my own chart with 3 pips resolution for today, with same datafeed CTS4 (i use sierrachart tick row for drawing my own chart - the sources is 100% same), but my chart is more.. volatile, more detalised with same numbers of points at chart. Just becouse of close differential can be 1 pips, and real movements was 2-3 pips, and as i said - the difference (losting) is increasing by increasing size of reversal move.
Sorry for my opinion... i use this "own" chart from 2001 year...May be this will be interesting for you... Just imagine, Point and Figure is losing information by cell sizes, but with this chart - we see ALL exactly values of prices, but without contr sizes (returning) less then pips sizes... Sorry again for long letter. Sierra - the best. i remember you from may be ... 2003 year
Good luck!
thisletterforme |at| gmail.com
Date Time Of Last Edit: 2014-06-05 09:21:13
[2014-06-05 12:24:44]
Between session last line and new session first line periodically occured base color chart line.
It seems to me, its happening if last price in old session is 18:52, first price of new session 19:01, but the rule was until 18:59:59 and new session started at 19:00:00...
http://enten.netne.net/f5.png
For my own chart this cases was a problem to ;-(( But i has solve this by drawing such line, not as line, but point-by-point (by bresenhaim alghorithm)
Date Time Of Last Edit: 2014-06-05 12:51:19
[2014-06-05 16:39:52]
Not sure how that could be solved.
[2014-06-05 17:47:32]
Well, i guess so ;) That's ok - dont worry! Thank you again.
