Date/Time: Sat, 30 Nov 2024 02:37:19 +0000
Replay Control Panel is not appearing, reset windows function does not make it appear
View Count: 459
[2022-10-24 18:15:01] |
Tavem - Posts: 1 |
Title says it all For some reason today the replay control panel refuses to appear. I have already tried restarting both the program and my computer as well as using the Windows menu's Reset Windows. When I hit reset Windows the Message log snaps into place and that is it. Control planel still refuses to open. I have tried with both the shortcut and from the menu Chart - Replay Chart - Replay Chart (Control Panel) |
[2022-10-25 22:04:24] |
Sierra_Chart Engineering - Posts: 17267 |
We have never known there to be a problem like this. Window >> Reset Windows is all you would need to do. And then you have to open it with Chart >> Replay Chart >> Replay Chart (Control Panel) The only thing we can think of is you can go back to an older configuration file at a time when you could see the Replay Control panel: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-25 22:04:46
[2022-12-25 23:38:27] |
John M - Posts: 171 |
As above but you need to hit "Reset Replay Control Panel Window". I had the same issue and this is what fixed it. |
[2022-12-26 04:05:25] |
Yes.
