Date/Time: Wed, 19 Mar 2025 13:55:01 +0000
Trade and Current Qoute Symbol - Orders & Chart DOM
View Count: 385
[2022-10-24 07:56:37]
Benutzer4711 - Posts: 35
I'm having some issues (or I don't understand the feature...) with the Trade and Current Qoute Symbol settings.
I've tested it in Sim only so far.
My setup:
Chart 1 - ES --> Thats my main/entry chart with setups and so on
Chart Settings:
Trade / Quote Symbol = NQ
Use as trade only Symbol = NO
Chart 2 - NQ --> thats where I manage my trade once active
1) The order amount information (e.g. bid/ask size + current bid/ask) in the Chart DOM is completely missing/blank in Chart 1 once Quote symbol is set?
2) Limit orders do not work? Entry only via buy/sell market
3) Open Limit + Attached Orders from Chart 1 not visible in Chart 2 at all // Filled + Attached orders visible in Chart 2 after Market buy/sell in Chart 1
I hope this is more or less clear.
[2022-10-24 11:14:30]
Sierra_Chart Engineering - Posts: 18841
Do you really want to use the NASDAQ futures (NQ) as the trade symbol and use ES futures as the chart? These are completely different contracts. There inherently will be various associated issues with this that are not resolvable.
Date Time Of Last Edit: 2022-10-24 11:15:11
[2022-10-24 11:45:25]
Yes, this is my intention. ES --> NQ
I see, that there are certain roadblocks ahead, more then expected.
[2022-10-24 12:02:44]
We cannot provide technical help for this. There are just too many associated complications. We do not recommend using this configuration at all.
You really need to use separate charts for this. One thing that you could do is overlay the ES chart onto an NQ chart that you use for trading by using this study:
Overlay - Bar
Date Time Of Last Edit: 2022-10-24 15:15:01
