Date/Time: Tue, 26 Nov 2024 02:50:13 +0000
Filter DOM Graph on chart and MBO orders
View Count: 675
[2022-10-21 19:20:15] |
kam2001 - Posts: 79 |
Unable to read DOM graph and MBO orders, as info is all cluttered up, can an option to filter DOM Graph and also filter MBO orders be provided, I've already added 'Minimum Market By Order Quantity' to 20 for symbols settings but it doesn't filter. See attached.
Screenshot (15).png / V - Attached On 2022-10-21 19:18:16 UTC - Size: 40.52 KB - 186 views Screenshot (17).png / V - Attached On 2022-10-21 19:19:45 UTC - Size: 88.06 KB - 153 views Attachment Deleted. |
[2022-10-21 19:55:30] |
John - SC Support - Posts: 36286 |
The filtering for the MBO data should be working. Did you select File >> Disconnect followed by File >> Connect to Data Feed after changing the Symbol Settings for that symbol to update the MBO data? Also, if you are using a Trade And Current Quote Symbol and do NOT have the option for Use as Trade Only Symbol then the Market Depth data in the DOM is for the Trade and Current Quote Symbol, therefore you would need to change the symbol settings for that Trade and Current Quote symbol to update the MBO data in the DOM. There is no filtering for the DOM Graph, but you can combine the increments for the Bid/Ask Market Depth, which will also reflect to the Chart DOM. Refer to the following: Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-24 10:44:10] |
Thanks, using combine increments has helped, but can i please ask to allow an actual option to filter the dom graph. and possibly an option to filter pulling/stacking column.
[2022-10-24 17:40:40] |
We have set this as a Feature Request. Just keep in mind that we do not know when, or if, we will get to any particular request.
[2023-09-20 12:58:07] |
Any updates ??
[2023-09-20 13:21:08] |
Sierra_Chart Engineering - Posts: 17179 |
Do you mean do not show levels below a certain quantity?: allow an actual option to filter the dom graph
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-09-20 13:21:14
[2023-09-20 15:31:24] |
Yes, that's correct - filter the dom graph
[2023-09-20 15:39:46] |
Rui S - Posts: 190 |
Exactly. This feature will be very useful. Thank you. |
[2024-01-12 09:40:27] |
any update ?
