Date/Time: Wed, 19 Mar 2025 09:42:08 +0000
Unable to get historical data to load if the contract has changed with a Rithmic feed
View Count: 390
[2022-10-18 22:52:14] |
User357195 - Posts: 123 |
SC: When I try to load a chart that has not been loaded since the prior contract expired, no data will be downloaded even if I use the edit download function in SC. The chart candles just start to build from the time I accessed the contract. For example, for the RTYZ2 contract, I had not tried to look at that symbol since RTYU2 was the front month. Now when I try to load up the RTY chart, it will just start from the new contract and then if I scroll back, the old contract data is there but there is a huge gap in the data. In this example, the gap in the chart is from about 09.16.22 until 10.17.22. 10.17.22 was the day I tried to open and view a RTYZ2 chart that hadn't been loaded since RTYU2 was the front month. I am a OneUpTrader using a Rithmic feed. Both OneUpTrader support and Rithmic support said I needed to contact Sierra Charts. I still think Sierra Charts are the best. Thanks in advance for your help. |
[2022-10-19 06:27:47] |
Sierra_Chart Engineering - Posts: 18841 |
We cannot help with this other than refer you to: Rithmic Trading Platform Service: Rithmic Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
