Date/Time: Wed, 19 Mar 2025 09:05:41 +0000
Cancel All button for Interactive Broker Dom
View Count: 387
[2022-10-17 21:51:06] |
User396 - Posts: 55 |
Cancel all, Flatten and Reverse buttons are grayed out for Interactive Brokers connection. Is that expected behavior? Or may be I am doing something wrong.
[2022-10-18 15:01:28] |
John - SC Support - Posts: 38782 |
Those buttons will not have any state based on the particular service connection. The most likely reason is that the settings for the controls has these off. Refer to the following: Global Trade Settings Windows: Display Trade Window Controls (Global Settings >> Chart Trade Settings >> General) Note that the "Cancel All" will also be "greyed out" when there are no working orders to cancel available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
