Date/Time: Wed, 19 Mar 2025 13:55:00 +0000
Requesting Account balances for web-based Teton Trade Account Data and Order Entry
View Count: 513
[2022-10-13 14:34:00]
eminimom - Posts: 24
This is the support inquiry response that didn't work for me:
[2022-05-08 11:23:48]#4[Go To First Post]
Sierra_Chart Engineering [Direct Messages] - Posts: 4376
We will check on this. This refers to Teton:
CME direct order routing
Still not functioning for me.
Once I have this: Trade Account Data and Order Entry-Sierra Chart CME Direct Order Routing, the next page that pops up is Server Selector/Sierra Chart CME Direct Order Routing-Advantage-Stage 5.
Then Connection Status, I selected Connect and it only stays on for less than 60seconds for Connected (Trading) and Connected(Data).
They both go to False time after time. My SC DTC Server. Build=43568 Data: SC Realtime Server.
[2022-10-17 18:32:22]
Sierra_Chart Engineering - Posts: 18841
What kind of device are you accessing this webpage from?
[2022-10-19 19:58:15]
A computer browser, Chrome. This is the link that worked before and it is the one in the support replies.
https://www.sierrachart.com/UserControlPanel.php?page=TradeAccountDataAndOrderEntry_v2&Service=sc_futures_direct.dtc.trading
Date Time Of Last Edit: 2022-10-19 19:59:46
[2022-10-24 15:10:25]
Hello, still waiting on a resolution for this. Was working perfectly when I converted from Transact to Stage5/Teton. Would appreciate knowing where we are on this. Thanks
[2022-10-25 17:14:15]
We are checking on this.
[2022-10-25 22:02:31]
Let us know if you still have a problem with this. We did make a change to handle reconnect in a scenario that was not handled.
