Date/Time: Wed, 19 Mar 2025 04:36:02 +0000
IB not downloading overnight historical data AGAIN!
View Count: 536
[2022-10-12 16:58:49] |
User56044 - Posts: 62 |
I have tried using IBs TWS v12 and v19 and neither version downloads overnight historical data. I was using TWS v12 yesterday (10/11/22) and it was working then. Anyone having the same problem? Anyone know a fit for this?
[2022-10-12 17:15:56] |
John - SC Support - Posts: 38782 |
One of the issues (hopefully the only issue) is that you are on Package 3 and in order to make a connection to an external service you need to be on one of our Integrated Package (packages 10, 11, and 12). We have set your account to Evaluate Package 12 for the next 60 days, so you do not need to make any changes at this time. Just be sure to remember to change to one of the Integrated Packages before the 60 days ends. Another possible item is that you need to be on the latest "Stable" release from IB. Do not use their Beta software (or whatever term they use for it), as there have been changes in that version that breaks our implementation for their data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-12 23:29:42] |
User584084 - Posts: 268 |
I am using IB Offline TWS Build 10.19.1c with SC Package 11 and do not have a problem downloading historical data. Historical data is downloading normally. No issues.
Date Time Of Last Edit: 2022-10-12 23:31:51
[2022-10-13 10:50:48] |
John, I am using the latest "Stable" release from IB but am still not able to download the overnight historical data. What could be amiss? |
[2022-10-13 11:44:22] |
Sierra_Chart Engineering - Posts: 18838 |
For what symbol? If it is a CME Group, EUREX, CFE or stock symbol you can easily access the data from our Denali Data Feed at a very minimal extra cost.
[2022-10-13 13:49:32] |
Using NYMEX Oil futures contract CL-202211. Also, the DPL works properly on one chart but not on another. How do I correct these issues?
