Date/Time: Wed, 19 Mar 2025 04:31:04 +0000
Data frozen
View Count: 450
[2022-10-11 15:09:51]
User633843 - Posts: 3
Hi, I have been using Teton order routing to trade on the CME for the past few months with no problems. Today, the charts updated the historical data once I logged in, but wont move from the updated price. I logged off and on several times, shut down the computer, updated Sierra to the current version but every time I login, it updates the historical data to the accurate price at that time, and then doesnt move.
Please help.
MS
[2022-10-11 15:49:48]
Sierra_Chart Engineering - Posts: 18837
If you still have an issue:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-10-11 16:08:17]
Hi, I followed all the instructions and the data is still frozen. Here is the log:
Software version: 2443 64-bit | 2022-10-11 15:58:15.513
Primary Thread ID: 14256 | 2022-10-11 15:58:15.513
Usage end date: 2022-10-17 | 2022-10-11 15:58:15.513
Enabled for: Advanced Features 2. | 2022-10-11 15:58:15.513
Enabled for: Sierra Chart Historical Data Service. | 2022-10-11 15:58:15.513
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-10-11 15:58:15.513
Enabled for: Delayed Denali Exchange Data Feed. | 2022-10-11 15:58:15.513
Enabled for exchange2: CME | 2022-10-11 15:58:15.513
Enabled for exchange2: fairx_exchange.data | 2022-10-11 15:58:15.513
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-10-11 15:58:15.513
Current selected Data/Trading service: Teton CME Order Routing | 2022-10-11 15:58:15.513
Custom symbol settings values: disabled | 2022-10-11 15:58:15.513
Chart Update Interval: 500 | 2022-10-11 15:58:15.513
Intraday Data Storage Time Unit: 1 | 2022-10-11 15:58:15.513
Time Zone: +00:00:00 (UTC+00) | 2022-10-11 15:58:15.513
2022-10-11 15:58:15 Local computer time in UTC | 2022-10-11 15:58:15.513
2022-10-11 15:58:15 Local computer time in SC Time Zone | 2022-10-11 15:58:15.513
2022-10-11 13:32:01 Server time in UTC | 2022-10-11 15:58:15.513
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-10-11 15:58:15.513
Program path: C:\SierraChart\ | 2022-10-11 15:58:15.513
Data Files path: C:\SierraChart\Data\ | 2022-10-11 15:58:15.513
OS Version Number: 10.0 | 2022-10-11 15:58:15.514
Locale Setting: C | 2022-10-11 15:58:15.514
DLLs: RiskMetrics_64.dll, UserContributedStudies_64.dll | 2022-10-11 15:58:15.514
Allowed protected custom studies: | 2022-10-11 15:58:15.514
Crash reporter started: true | 2022-10-11 15:58:15.514
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-10-11 15:58:30.106
DTC Client socket (2) | Creating socket. | 2022-10-11 15:58:30.111
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 15:58:30.111
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-10-11 15:58:30.111
SC Data - All Services | Network connection to server complete. | 2022-10-11 15:58:30.336
SC Data - All Services | Starting socket receive thread. | 2022-10-11 15:58:30.336
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 15:58:30.336
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 15:58:30.430
SC Data - All Services | Sending logon request message. | 2022-10-11 15:58:30.430
SC Data - All Services | Received logon response. | 2022-10-11 15:58:31.130
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 15:58:31.130
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 15:58:31.130
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 15:58:31.130
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 15:58:31.130
DTC Client socket (2) | CloseSocket call. | 2022-10-11 15:58:31.130
SC Data - All Services | Disconnected from the server. | 2022-10-11 15:58:31.130
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 15:58:31.130
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:58:31.130
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 15:58:31.190
DTC Client socket (2) | Closed. | 2022-10-11 15:58:31.190
File >> Disconnect selected. | 2022-10-11 15:58:35.758
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-10-11 15:58:35.759
DTC Client socket (1) | CloseSocket call. | 2022-10-11 15:58:35.759
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-10-11 15:58:35.759
DTC Client socket (1) | Max send buffer size during socket life: 236 | 2022-10-11 15:58:35.759
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:58:35.759
DTC Client socket (0) | CloseSocket call. | 2022-10-11 15:58:35.760
SC Data - All Services | Disconnected from the server. | 2022-10-11 15:58:35.760
Teton CME Order Routing | Disconnected. | 2022-10-11 15:58:35.760
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-11 15:58:35.798
DTC Client socket (1) | Closed. | 2022-10-11 15:58:35.798
Teton CME Order Routing | Firm: IronBeam | 2022-10-11 15:58:37.795
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 | 2022-10-11 15:58:37.795
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-11 15:58:37.795
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-11 15:58:37.796
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-10-11 15:58:37.796
Teton CME Order Routing | Network connection to server complete. | 2022-10-11 15:58:37.837
Teton CME Order Routing | Starting socket receive thread. | 2022-10-11 15:58:37.837
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-10-11 15:58:37.837
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-10-11 15:58:37.945
Teton CME Order Routing | Sending logon request message. | 2022-10-11 15:58:37.945
Teton CME Order Routing | Received logon response. | 2022-10-11 15:58:38.752
Teton CME Order Routing | Server Name: SC DTC Server. Build=43649. | 2022-10-11 15:58:38.752
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 15:58:38.752
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-10-11 15:58:38.752
Teton CME Order Routing | Trading is supported. | 2022-10-11 15:58:38.752
Teton CME Order Routing | Order cancel and replace is supported. | 2022-10-11 15:58:38.752
Teton CME Order Routing | OCO Orders supported. | 2022-10-11 15:58:38.752
Teton CME Order Routing | Bracket Orders supported. | 2022-10-11 15:58:38.752
Teton CME Order Routing | Connected to server complete. | 2022-10-11 15:58:38.752
Triggering next historical data download in queue. | 2022-10-11 15:58:38.752
Updated verified funded futures trading account ending date to: 2022-11-10 15:58:38 | 2022-10-11 15:58:38.752
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-10-11 15:58:38.753
No download requests in the queue to start downloads for. | 2022-10-11 15:58:38.753
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-10-07 17:17:28.221108 | 2022-10-11 15:58:38.762
Updated verified funded futures trading account ending date to: 2022-11-10 15:58:38 | 2022-10-11 15:58:38.781
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=31602710 | 2022-10-11 15:58:38.797
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-10-11 15:58:38.996
Using symbol data fast lookup vector | 2022-10-11 15:58:38.996
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 1 Service code: cme | 2022-10-11 15:58:38.996
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-10-11 15:58:38.996
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 1 | 2022-10-11 15:58:38.997
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-10-11 15:58:38.997
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-10-11 15:58:38.997
Triggering next historical data download in queue. | 2022-10-11 15:58:38.997
DTC Client socket (2) | Creating socket. | 2022-10-11 15:58:38.998
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 15:58:38.998
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-10-11 15:58:38.998
Delaying start of download for ESZ22_FUT_CME. | 2022-10-11 15:58:39.009
Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-10-11 15:58:39.017
SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 2 Service code: cme | 2022-10-11 15:58:39.017
SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 2 | 2022-10-11 15:58:39.018
Added historical Intraday data request for MESZ22_FUT_CME to the queue. | 2022-10-11 15:58:39.018
Intraday data recording state for symbol MESZ22_FUT_CME is set to download 'Pending'. | 2022-10-11 15:58:39.018
Triggering next historical data download in queue. | 2022-10-11 15:58:39.018
SC Data - All Services | Network connection to server complete. | 2022-10-11 15:58:39.044
SC Data - All Services | Starting socket receive thread. | 2022-10-11 15:58:39.044
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 15:58:39.044
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-10-11 15:58:39.087
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-11 15:58:39.087
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ22_FUT_CME | 2022-10-11 15:58:39.087
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-11 15:58:39.087
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 15:58:39.112
SC Data - All Services | Sending logon request message. | 2022-10-11 15:58:39.112
SC Data - All Services | Received logon response. | 2022-10-11 15:58:39.768
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 15:58:39.768
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 15:58:39.768
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 15:58:39.768
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 15:58:39.768
DTC Client socket (2) | CloseSocket call. | 2022-10-11 15:58:39.769
SC Data - All Services | Disconnected from the server. | 2022-10-11 15:58:39.769
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 15:58:39.769
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:58:39.769
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 15:58:39.812
DTC Client socket (2) | Closed. | 2022-10-11 15:58:39.812
HD Request # 15 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-10-11 15:59:09.405
HD Request # 15 | Download start date-time: 2022-10-11 15:57:27.000000. File last date-time: 2022-10-11 15:57:27.124000 | 2022-10-11 15:59:09.406
HD Request # 15 | Using server: ds21.sierracharts.com port 10150 | 2022-10-11 15:59:09.406
Socket (2) | Creating socket. | 2022-10-11 15:59:09.406
Socket (2) | New receive buffer size: 5242880 | 2022-10-11 15:59:09.407
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-10-11 15:59:09.407
HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-10-11 15:59:09.510
HD Request # 15 | Sending historical data logon request message. | 2022-10-11 15:59:09.510
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-10-11 15:59:09.778
DTC Client socket (3) | Creating socket. | 2022-10-11 15:59:09.785
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-10-11 15:59:09.785
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-10-11 15:59:09.785
SC Data - All Services | Network connection to server complete. | 2022-10-11 15:59:09.848
SC Data - All Services | Starting socket receive thread. | 2022-10-11 15:59:09.848
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 15:59:09.848
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 15:59:09.898
SC Data - All Services | Sending logon request message. | 2022-10-11 15:59:09.898
HD Request # 15 | Requesting Intraday data. Start date-time: 2022-10-11 15:57:27. Record interval: 1. Symbol: ESZ22 | 2022-10-11 15:59:10.021
HD Request # 15 | Decompressing data. | 2022-10-11 15:59:10.060
HD Request # 15 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-10-11 15:57:27.124000 | 2022-10-11 15:59:10.062
Socket (2) | CloseSocket call. | 2022-10-11 15:59:10.064
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:59:10.064
Historical data download thread signaled to stop. | 2022-10-11 15:59:10.064
HD Request # 15 | Timestamp of first Intraday data file record written: 2022-10-11 15:57:27.124000. | 2022-10-11 15:59:10.064
HD Request # 15 | Received 102 Intraday data records from 2022-10-11 15:57:27.124000 to 2022-10-11 15:59:09.005000 (101.9 seconds) and wrote 102 records for ESZ22_FUT_CME | 2022-10-11 15:59:10.064
HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-10-11 15:59:09.005000 | 2022-10-11 15:59:10.072
HD Request # 15 | Completion time: 1s. | 2022-10-11 15:59:10.072
HD Request # 15 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 15 | 2022-10-11 15:59:10.072
Removing historical data download ID 15. | 2022-10-11 15:59:10.072
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-10-11 15:59:10.072
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 14256 | 2022-10-11 15:59:10.072
Intraday chart data file opened for ESZ22_FUT_CME | 2022-10-11 15:59:10.072
HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-10-11 15:59:10.072
Triggering next historical data download in queue. | 2022-10-11 15:59:10.072
HD Request # 16 | Downloading Intraday chart data for MESZ22_FUT_CME to the file MESZ22_FUT_CME.scid. Service: cme | 2022-10-11 15:59:10.072
HD Request # 16 | Download start date-time: 2022-10-11 15:57:27.000000. File last date-time: 2022-10-11 15:57:27.110000 | 2022-10-11 15:59:10.073
HD Request # 16 | Using server: ds23.sierracharts.com port 10149 | 2022-10-11 15:59:10.073
Socket (4) | Creating socket. | 2022-10-11 15:59:10.073
Socket (4) | New receive buffer size: 5242880 | 2022-10-11 15:59:10.073
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-10-11 15:59:10.073
Socket (2) | Socket gracefully closed by remote side. | 2022-10-11 15:59:10.112
Socket (2) | Closed. | 2022-10-11 15:59:10.112
HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-10-11 15:59:10.207
HD Request # 16 | Sending historical data logon request message. | 2022-10-11 15:59:10.207
HD Request # 16 | Requesting Intraday data. Start date-time: 2022-10-11 15:57:27. Record interval: 1. Symbol: MESZ22 | 2022-10-11 15:59:10.756
SC Data - All Services | Received logon response. | 2022-10-11 15:59:10.780
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 15:59:10.780
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 15:59:10.780
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 15:59:10.780
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 15:59:10.780
DTC Client socket (3) | CloseSocket call. | 2022-10-11 15:59:10.780
SC Data - All Services | Disconnected from the server. | 2022-10-11 15:59:10.781
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 15:59:10.781
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:59:10.781
HD Request # 16 | Decompressing data. | 2022-10-11 15:59:10.811
DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-10-11 15:59:10.815
DTC Client socket (3) | Closed. | 2022-10-11 15:59:10.815
HD Request # 16 | Receiving Intraday data for MESZ22_FUT_CME starting at 2022-10-11 15:57:27.110000 | 2022-10-11 15:59:10.817
Socket (4) | CloseSocket call. | 2022-10-11 15:59:10.818
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:59:10.818
Historical data download thread signaled to stop. | 2022-10-11 15:59:10.819
HD Request # 16 | Timestamp of first Intraday data file record written: 2022-10-11 15:57:27.110000. | 2022-10-11 15:59:10.819
HD Request # 16 | Received 101 Intraday data records from 2022-10-11 15:57:27.110000 to 2022-10-11 15:59:08.273000 (101.2 seconds) and wrote 101 records for MESZ22_FUT_CME | 2022-10-11 15:59:10.819
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2022-10-11 15:59:08.273000 | 2022-10-11 15:59:10.827
HD Request # 16 | Completion time: 0s. | 2022-10-11 15:59:10.827
HD Request # 16 | Intraday data download complete for MESZ22_FUT_CME. Unique request ID: 16 | 2022-10-11 15:59:10.827
Removing historical data download ID 16. | 2022-10-11 15:59:10.827
Real-time Intraday chart data file updates started for MESZ22_FUT_CME | 2022-10-11 15:59:10.827
Opened cached Intraday file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. Thread ID: 14256 | 2022-10-11 15:59:10.827
Intraday chart data file opened for MESZ22_FUT_CME | 2022-10-11 15:59:10.827
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-10-11 15:59:10.827
Triggering next historical data download in queue. | 2022-10-11 15:59:10.827
No download requests in the queue to start downloads for. | 2022-10-11 15:59:10.827
Socket (4) | Socket gracefully closed by remote side. | 2022-10-11 15:59:10.867
Socket (4) | Closed. | 2022-10-11 15:59:10.867
SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 10048 | 2022-10-11 15:59:40.760
DTC Client socket (2) | Creating socket. | 2022-10-11 15:59:40.761
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 15:59:40.762
DTC Client socket (2) | Connecting to IP: 208.185.224.128. | 2022-10-11 15:59:40.762
SC Data - All Services | Network connection to server complete. | 2022-10-11 15:59:40.798
SC Data - All Services | Starting socket receive thread. | 2022-10-11 15:59:40.798
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 15:59:40.798
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 15:59:40.864
SC Data - All Services | Sending logon request message. | 2022-10-11 15:59:40.864
SC Data - All Services | Received logon response. | 2022-10-11 15:59:41.489
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 15:59:41.489
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 15:59:41.489
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 15:59:41.489
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 15:59:41.489
DTC Client socket (2) | CloseSocket call. | 2022-10-11 15:59:41.490
SC Data - All Services | Disconnected from the server. | 2022-10-11 15:59:41.490
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 15:59:41.490
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 15:59:41.490
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 15:59:41.522
DTC Client socket (2) | Closed. | 2022-10-11 15:59:41.522
ESZ22 Daily #5 | Reloading chart. | 2022-10-11 16:00:11.212
Enabling compression for file: C:\SierraChart\Data\ESZ22.dly. This may take a while. | 2022-10-11 16:00:11.213
File compression enabled. C:\SierraChart\Data\ESZ22.dly. CompressionState=2 | 2022-10-11 16:00:11.213
ESZ22 Daily #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ22.dly | 2022-10-11 16:00:11.216
SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 443 | 2022-10-11 16:00:11.484
DTC Client socket (2) | Creating socket. | 2022-10-11 16:00:11.485
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:00:11.485
DTC Client socket (2) | Connecting to IP: 142.215.18.107. | 2022-10-11 16:00:11.485
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:00:11.648
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:00:11.648
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:00:11.648
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:00:11.729
SC Data - All Services | Sending logon request message. | 2022-10-11 16:00:11.729
Starting DelayedDownloadMonitoringTimer | 2022-10-11 16:00:11.752
Starting HDTimeoutTimer | 2022-10-11 16:00:11.752
Added historical Daily data request for ESZ22 to the queue. | 2022-10-11 16:00:11.752
Triggering next historical data download in queue. | 2022-10-11 16:00:11.752
Teton CME Order Routing | Starting real-time market data updates for: ESZ22. ID: 3 | 2022-10-11 16:00:11.752
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: ESZ22 | 2022-10-11 16:00:11.752
Teton CME Order Routing | Requesting security definition data for: ESZ22. ID: 3 | 2022-10-11 16:00:11.752
HD Request # 17 | Downloading Historical Daily chart data for ESZ22. Starting date: 1972-10-11. Service: nasdaq_exchange.data | 2022-10-11 16:00:11.752
Teton CME Order Routing | Received security definition for symbol ESZ22 | 2022-10-11 16:00:11.809
SC Data - All Services | Received logon response. | 2022-10-11 16:00:12.412
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:00:12.412
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:00:12.412
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:00:12.412
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:00:12.412
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:00:12.412
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:00:12.412
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:00:12.412
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:00:12.412
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:00:12.463
DTC Client socket (2) | Closed. | 2022-10-11 16:00:12.463
HD Request # 17 | Requesting historical Daily data for ESZ22 starting at 1972-10-10. SC External HD service. | 2022-10-11 16:00:12.784
HD Request # 17 | Receiving historical Daily data for ESZ22 starting at 2021-06-04. | 2022-10-11 16:00:13.081
HD Request # 17 | Writing historical Daily data to the file ESZ22.dly. | 2022-10-11 16:00:13.082
HD Request # 17 | Bytes received: 17726 | 2022-10-11 16:00:13.097
HD Request # 17 | Received 341 Daily data records from 2021-06-04 00:00:00 to 2022-10-10 00:00:00 (494.0 days) and wrote 341 records for ESZ22 | 2022-10-11 16:00:13.097
HD Request # 17 | Completion time: 2s. | 2022-10-11 16:00:13.097
HD Request # 17 | Daily data download complete for ESZ22. Unique request ID: 17 | 2022-10-11 16:00:13.097
Removing historical data download ID 17. | 2022-10-11 16:00:13.097
Triggering next historical data download in queue. | 2022-10-11 16:00:13.097
No download requests in the queue to start downloads for. | 2022-10-11 16:00:13.098
ESZ22 Daily #5 | Reloading chart. | 2022-10-11 16:00:13.232
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-10-11 16:00:42.565
DTC Client socket (2) | Creating socket. | 2022-10-11 16:00:42.571
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:00:42.571
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-10-11 16:00:42.571
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:00:42.618
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:00:42.618
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:00:42.618
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:00:42.687
SC Data - All Services | Sending logon request message. | 2022-10-11 16:00:42.687
SC Data - All Services | Received logon response. | 2022-10-11 16:00:43.781
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:00:43.781
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:00:43.781
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:00:43.781
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:00:43.781
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:00:43.781
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:00:43.781
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:00:43.781
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:00:43.781
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:00:43.828
DTC Client socket (2) | Closed. | 2022-10-11 16:00:43.828
F.US.EPZ21 Daily #5 | Reloading chart. | 2022-10-11 16:01:03.798
No historical data client is currently set to download historical Daily data for F.US.EPZ21. | 2022-10-11 16:01:04.288
Teton CME Order Routing | Starting real-time market data updates for: F.US.EPZ21. ID: 4 | 2022-10-11 16:01:04.289
Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.EPZ21 | 2022-10-11 16:01:04.289
Teton CME Order Routing | Requesting security definition data for: F.US.EPZ21. ID: 4 | 2022-10-11 16:01:04.289
Teton CME Order Routing | Received security definition for symbol F.US.EPZ21 | 2022-10-11 16:01:04.317
F.US.EPZ21 Daily #5 | Reloading chart. | 2022-10-11 16:01:04.798
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-10-11 16:01:13.778
DTC Client socket (2) | Creating socket. | 2022-10-11 16:01:13.781
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:01:13.781
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-10-11 16:01:13.781
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:01:13.828
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:01:13.828
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:01:13.828
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:01:13.886
SC Data - All Services | Sending logon request message. | 2022-10-11 16:01:13.887
SC Data - All Services | Received logon response. | 2022-10-11 16:01:14.561
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:01:14.561
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:01:14.561
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:01:14.561
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:01:14.561
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:01:14.562
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:01:14.562
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:01:14.562
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:01:14.562
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:01:14.615
DTC Client socket (2) | Closed. | 2022-10-11 16:01:14.615
Enabling compression for file: C:\SierraChart\Data\ESZ22_FUT_CME.dly. This may take a while. | 2022-10-11 16:01:32.094
File compression enabled. C:\SierraChart\Data\ESZ22_FUT_CME.dly. CompressionState=0 | 2022-10-11 16:01:32.094
ESZ22_FUT_CME Daily #5 | Reloading chart. | 2022-10-11 16:01:32.097
ESZ22_FUT_CME Daily #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ22_FUT_CME.dly | 2022-10-11 16:01:32.114
Added historical Daily data request for ESZ22_FUT_CME to the queue. | 2022-10-11 16:01:32.605
Triggering next historical data download in queue. | 2022-10-11 16:01:32.605
HD Request # 18 | Downloading Historical Daily chart data for ESZ22_FUT_CME. Starting date: 1972-10-11. Service: sc_futures_direct.dtc.trading | 2022-10-11 16:01:32.612
HD Request # 18 | Requesting historical Daily data for ESZ22 starting at 1972-10-10. SC External HD service. | 2022-10-11 16:01:33.655
HD Request # 18 | Receiving historical Daily data for ESZ22_FUT_CME starting at 2021-06-04. | 2022-10-11 16:01:33.866
HD Request # 18 | Writing historical Daily data to the file ESZ22_FUT_CME.dly. | 2022-10-11 16:01:33.867
HD Request # 18 | Bytes received: 17726 | 2022-10-11 16:01:33.880
HD Request # 18 | Received 341 Daily data records from 2021-06-04 00:00:00 to 2022-10-10 00:00:00 (494.0 days) and wrote 341 records for ESZ22_FUT_CME | 2022-10-11 16:01:33.881
HD Request # 18 | Completion time: 1s. | 2022-10-11 16:01:33.881
HD Request # 18 | Daily data download complete for ESZ22_FUT_CME. Unique request ID: 18 | 2022-10-11 16:01:33.881
Removing historical data download ID 18. | 2022-10-11 16:01:33.881
Triggering next historical data download in queue. | 2022-10-11 16:01:33.881
No download requests in the queue to start downloads for. | 2022-10-11 16:01:33.881
ESZ22_FUT_CME[M] Daily #5 | Reloading chart. | 2022-10-11 16:01:34.147
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-10-11 16:01:44.570
DTC Client socket (2) | Creating socket. | 2022-10-11 16:01:44.570
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:01:44.570
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-10-11 16:01:44.570
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:01:44.618
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:01:44.618
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:01:44.618
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:01:44.675
SC Data - All Services | Sending logon request message. | 2022-10-11 16:01:44.675
SC Data - All Services | Received logon response. | 2022-10-11 16:01:45.294
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:01:45.294
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:01:45.294
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:01:45.294
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:01:45.294
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:01:45.295
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:01:45.295
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:01:45.295
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:01:45.295
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:01:45.327
DTC Client socket (2) | Closed. | 2022-10-11 16:01:45.327
SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 10048 | 2022-10-11 16:02:15.309
DTC Client socket (2) | Creating socket. | 2022-10-11 16:02:15.310
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:02:15.310
DTC Client socket (2) | Connecting to IP: 208.185.224.128. | 2022-10-11 16:02:15.310
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:02:15.355
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:02:15.355
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:02:15.355
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:02:15.408
SC Data - All Services | Sending logon request message. | 2022-10-11 16:02:15.408
SC Data - All Services | Received logon response. | 2022-10-11 16:02:16.049
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:02:16.049
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:02:16.049
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:02:16.049
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:02:16.049
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:02:16.050
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:02:16.050
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:02:16.050
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:02:16.050
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:02:16.082
DTC Client socket (2) | Closed. | 2022-10-11 16:02:16.082
File >> Disconnect selected. | 2022-10-11 16:02:20.948
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-10-11 16:02:20.948
DTC Client socket (1) | CloseSocket call. | 2022-10-11 16:02:20.948
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-10-11 16:02:20.948
DTC Client socket (1) | Max send buffer size during socket life: 329 | 2022-10-11 16:02:20.948
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:02:20.948
DTC Client socket (0) | CloseSocket call. | 2022-10-11 16:02:20.948
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:02:20.948
Teton CME Order Routing | Disconnected. | 2022-10-11 16:02:20.948
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-11 16:02:20.982
DTC Client socket (1) | Closed. | 2022-10-11 16:02:20.983
Teton CME Order Routing | Firm: IronBeam | 2022-10-11 16:02:28.528
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 | 2022-10-11 16:02:28.528
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-11 16:02:28.617
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-11 16:02:28.617
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-10-11 16:02:28.617
Teton CME Order Routing | Network connection to server complete. | 2022-10-11 16:02:28.654
Teton CME Order Routing | Starting socket receive thread. | 2022-10-11 16:02:28.654
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-10-11 16:02:28.654
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-10-11 16:02:28.759
Teton CME Order Routing | Sending logon request message. | 2022-10-11 16:02:28.759
Teton CME Order Routing | Received logon response. | 2022-10-11 16:02:29.274
Teton CME Order Routing | Server Name: SC DTC Server. Build=43649. | 2022-10-11 16:02:29.274
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:02:29.274
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-10-11 16:02:29.274
Teton CME Order Routing | Trading is supported. | 2022-10-11 16:02:29.274
Teton CME Order Routing | Order cancel and replace is supported. | 2022-10-11 16:02:29.274
Teton CME Order Routing | OCO Orders supported. | 2022-10-11 16:02:29.274
Teton CME Order Routing | Bracket Orders supported. | 2022-10-11 16:02:29.274
Teton CME Order Routing | Connected to server complete. | 2022-10-11 16:02:29.274
Triggering next historical data download in queue. | 2022-10-11 16:02:29.275
Updated verified funded futures trading account ending date to: 2022-11-10 16:02:29 | 2022-10-11 16:02:29.275
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-10-11 16:02:29.278
No download requests in the queue to start downloads for. | 2022-10-11 16:02:29.278
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-10-07 17:17:28.221108 | 2022-10-11 16:02:29.287
Updated verified funded futures trading account ending date to: 2022-11-10 16:02:29 | 2022-10-11 16:02:29.309
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=31602710 | 2022-10-11 16:02:29.324
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-10-11 16:02:29.560
Using symbol data fast lookup vector | 2022-10-11 16:02:29.560
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 1 Service code: cme | 2022-10-11 16:02:29.560
SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-10-11 16:02:29.560
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 1 | 2022-10-11 16:02:29.560
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-10-11 16:02:29.560
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-10-11 16:02:29.560
Triggering next historical data download in queue. | 2022-10-11 16:02:29.560
DTC Client socket (2) | Creating socket. | 2022-10-11 16:02:29.565
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:02:29.565
DTC Client socket (2) | Connecting to IP: 142.215.18.107. | 2022-10-11 16:02:29.565
Delaying start of download for ESZ22_FUT_CME. | 2022-10-11 16:02:29.569
Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-10-11 16:02:29.577
SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 2 Service code: cme | 2022-10-11 16:02:29.577
SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 2 | 2022-10-11 16:02:29.577
Added historical Intraday data request for MESZ22_FUT_CME to the queue. | 2022-10-11 16:02:29.577
Intraday data recording state for symbol MESZ22_FUT_CME is set to download 'Pending'. | 2022-10-11 16:02:29.577
Triggering next historical data download in queue. | 2022-10-11 16:02:29.577
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ22_FUT_CME | 2022-10-11 16:02:29.590
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-11 16:02:29.590
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ22_FUT_CME | 2022-10-11 16:02:29.604
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-11 16:02:29.604
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:02:29.617
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:02:29.617
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:02:29.617
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:02:29.684
SC Data - All Services | Sending logon request message. | 2022-10-11 16:02:29.684
SC Data - All Services | Received logon response. | 2022-10-11 16:02:30.354
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:02:30.354
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:02:30.354
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:02:30.354
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:02:30.354
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:02:30.354
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:02:30.354
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:02:30.354
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:02:30.354
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:02:30.400
DTC Client socket (2) | Closed. | 2022-10-11 16:02:30.400
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-10-11 16:03:00.361
DTC Client socket (2) | Creating socket. | 2022-10-11 16:03:00.362
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:03:00.362
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-10-11 16:03:00.362
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:03:00.421
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:03:00.421
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:03:00.421
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:03:00.499
SC Data - All Services | Sending logon request message. | 2022-10-11 16:03:00.499
HD Request # 19 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-10-11 16:03:00.567
HD Request # 19 | Download start date-time: 2022-10-11 15:59:09.000000. File last date-time: 2022-10-11 15:59:09.005000 | 2022-10-11 16:03:00.567
HD Request # 19 | Using server: ds26.sierracharts.com port 10150 | 2022-10-11 16:03:00.567
Socket (3) | Creating socket. | 2022-10-11 16:03:00.568
Socket (3) | New receive buffer size: 5242880 | 2022-10-11 16:03:00.568
Socket (3) | Connecting to IP: 142.215.18.107. | 2022-10-11 16:03:00.568
HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-10-11 16:03:00.654
HD Request # 19 | Sending historical data logon request message. | 2022-10-11 16:03:00.654
SC Data - All Services | Received logon response. | 2022-10-11 16:03:01.158
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:03:01.158
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:03:01.158
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:03:01.158
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:03:01.158
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:03:01.159
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:03:01.159
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:03:01.159
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:03:01.159
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:03:01.204
DTC Client socket (2) | Closed. | 2022-10-11 16:03:01.204
HD Request # 19 | Requesting Intraday data. Start date-time: 2022-10-11 15:59:09. Record interval: 1. Symbol: ESZ22 | 2022-10-11 16:03:01.206
HD Request # 19 | Decompressing data. | 2022-10-11 16:03:01.260
HD Request # 19 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-10-11 15:59:09.005000 | 2022-10-11 16:03:01.263
Socket (3) | CloseSocket call. | 2022-10-11 16:03:01.264
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:03:01.264
Historical data download thread signaled to stop. | 2022-10-11 16:03:01.264
HD Request # 19 | Timestamp of first Intraday data file record written: 2022-10-11 15:59:09.005000. | 2022-10-11 16:03:01.264
HD Request # 19 | Received 227 Intraday data records from 2022-10-11 15:59:09.005000 to 2022-10-11 16:02:57.331000 (3.8 minutes) and wrote 227 records for ESZ22_FUT_CME | 2022-10-11 16:03:01.264
HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-10-11 16:02:57.331000 | 2022-10-11 16:03:01.270
HD Request # 19 | Completion time: 1s. | 2022-10-11 16:03:01.270
HD Request # 19 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 19 | 2022-10-11 16:03:01.270
Removing historical data download ID 19. | 2022-10-11 16:03:01.270
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-10-11 16:03:01.270
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 14256 | 2022-10-11 16:03:01.270
Intraday chart data file opened for ESZ22_FUT_CME | 2022-10-11 16:03:01.270
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-10-11 16:03:01.270
Triggering next historical data download in queue. | 2022-10-11 16:03:01.270
HD Request # 20 | Downloading Intraday chart data for MESZ22_FUT_CME to the file MESZ22_FUT_CME.scid. Service: cme | 2022-10-11 16:03:01.270
HD Request # 20 | Download start date-time: 2022-10-11 15:59:08.000000. File last date-time: 2022-10-11 15:59:08.273000 | 2022-10-11 16:03:01.270
HD Request # 20 | Using server: ds21.sierracharts.com port 10149 | 2022-10-11 16:03:01.271
Socket (2) | Creating socket. | 2022-10-11 16:03:01.271
Socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:03:01.271
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-10-11 16:03:01.271
Socket (3) | Socket gracefully closed by remote side. | 2022-10-11 16:03:01.305
Socket (3) | Closed. | 2022-10-11 16:03:01.305
HD Request # 20 | Setting DTC encoding to Binary VLS | 2022-10-11 16:03:01.369
HD Request # 20 | Sending historical data logon request message. | 2022-10-11 16:03:01.369
HD Request # 20 | Requesting Intraday data. Start date-time: 2022-10-11 15:59:08. Record interval: 1. Symbol: MESZ22 | 2022-10-11 16:03:01.912
HD Request # 20 | Decompressing data. | 2022-10-11 16:03:01.949
HD Request # 20 | Receiving Intraday data for MESZ22_FUT_CME starting at 2022-10-11 15:59:08.273000 | 2022-10-11 16:03:01.951
Socket (2) | CloseSocket call. | 2022-10-11 16:03:01.953
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:03:01.953
Socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:03:02.008
Socket (2) | Closed. | 2022-10-11 16:03:02.008
Historical data download thread signaled to stop. | 2022-10-11 16:03:02.013
HD Request # 20 | Timestamp of first Intraday data file record written: 2022-10-11 15:59:08.273000. | 2022-10-11 16:03:02.013
HD Request # 20 | Received 230 Intraday data records from 2022-10-11 15:59:08.273000 to 2022-10-11 16:02:58.164000 (3.8 minutes) and wrote 230 records for MESZ22_FUT_CME | 2022-10-11 16:03:02.013
HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2022-10-11 16:02:58.164000 | 2022-10-11 16:03:02.018
HD Request # 20 | Completion time: 1s. | 2022-10-11 16:03:02.018
HD Request # 20 | Intraday data download complete for MESZ22_FUT_CME. Unique request ID: 20 | 2022-10-11 16:03:02.018
Removing historical data download ID 20. | 2022-10-11 16:03:02.018
Real-time Intraday chart data file updates started for MESZ22_FUT_CME | 2022-10-11 16:03:02.018
Opened cached Intraday file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. Thread ID: 14256 | 2022-10-11 16:03:02.018
Intraday chart data file opened for MESZ22_FUT_CME | 2022-10-11 16:03:02.018
HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-10-11 16:03:02.018
Triggering next historical data download in queue. | 2022-10-11 16:03:02.018
No download requests in the queue to start downloads for. | 2022-10-11 16:03:02.018
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-10-11 16:03:31.160
DTC Client socket (2) | Creating socket. | 2022-10-11 16:03:31.161
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:03:31.162
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-10-11 16:03:31.162
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:03:31.213
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:03:31.213
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:03:31.213
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:03:31.262
SC Data - All Services | Sending logon request message. | 2022-10-11 16:03:31.262
SC Data - All Services | Received logon response. | 2022-10-11 16:03:31.921
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:03:31.921
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:03:31.921
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:03:31.921
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:03:31.921
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:03:31.921
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:03:31.921
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:03:31.921
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:03:31.921
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:03:31.966
DTC Client socket (2) | Closed. | 2022-10-11 16:03:31.966
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-10-11 16:04:01.900
DTC Client socket (2) | Creating socket. | 2022-10-11 16:04:01.901
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-11 16:04:01.901
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-10-11 16:04:01.901
SC Data - All Services | Network connection to server complete. | 2022-10-11 16:04:01.931
SC Data - All Services | Starting socket receive thread. | 2022-10-11 16:04:01.931
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-11 16:04:01.931
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-11 16:04:01.983
SC Data - All Services | Sending logon request message. | 2022-10-11 16:04:01.983
SC Data - All Services | Received logon response. | 2022-10-11 16:04:02.626
SC Data - All Services | Server Name: RealTime Server. | 2022-10-11 16:04:02.626
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-11 16:04:02.626
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-10-11 16:04:02.626
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-11 16:04:02.626
DTC Client socket (2) | CloseSocket call. | 2022-10-11 16:04:02.626
SC Data - All Services | Disconnected from the server. | 2022-10-11 16:04:02.626
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-10-11 16:04:02.626
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-11 16:04:02.627
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-11 16:04:02.655
DTC Client socket (2) | Closed. | 2022-10-11 16:04:02.655
[2022-10-11 16:23:16]
John - SC Support - Posts: 38782
The following is the relevant message:
You can only access the Denali Exchange Data Feed from one computer at a time. There is another computer running Sierra Chart that is connected to the Denali Exchange Data Feed. You would either need to disconnect that computer in order to use this one, or you can setup your account to allow you to get the data to two different computers at the same time (the cost is that you need to pay the exchange fee again).
Refer to the following section of the documentation regarding the connections available for the Denali Exchange Data Feed:
Denali Exchange Data Feed: Connections
[2022-10-11 16:26:29]
Solved, thank you so much. Yes, we have a test computer with SierraChart Data and a live trading computer with Denali Data. Once I closed Sierra Chart on the test computer, my data feed on the trading computer came back online.
Thanks again,
MS
