Date/Time: Wed, 19 Mar 2025 03:24:40 +0000
Adding a study to custom Study Button
View Count: 340
[2022-10-10 17:48:53]
User29419 - Posts: 19
I have added a Custom Study Button to the Control Bar. How do I add a study to turn on/off when the study button is clicked? I want to be able to turn VWAP on or off when the button is clicked. Thanks
[2022-10-10 21:26:36]
John - SC Support - Posts: 38782
There is not a way to Show/Hide a study through Control Bar buttons or keyboard shortcuts. As you have found the way to add a study, the same principle applies to removing it. In that what you need to do is to create a Study Collection that has the other studies you still want on the chart, but not the VWAP (or use the "Clean Chart" study collection, if the VWAP is the only one you are using).
Also consider the Show/Hide options, as these are available from the right-click menu and are not that difficult to access. Refer to the following:
Chart Studies: Hiding and Showing Study Directly from Chart
