Date/Time: Wed, 19 Mar 2025 02:26:44 +0000
Treasury chart questions
View Count: 386
[2022-10-06 12:29:20] |
Steve Leon - Posts: 312 |
I am attaching the following chart with these question 1) I dont understand why my session lines/times are not showing at 8:20 am est start time as i have it in the session times as the start time. 2) I also dont know why i am missing the overnight information after midnight until the time i loaded my charts. i reloaded/recalculated the charts but same thing persists Thank you |
[2022-10-06 15:06:48] |
John - SC Support - Posts: 38782 |
1. It looks like your setting for Chart >> Chart Settings >> Grid >> Vertical Grid Interval Type is set to Start of Trading Day. It sounds like you want it to be set to Session Start so it will show you the start of both the Evening and Regular session. 2. We do not know why that data is missing. Try deleting and redownloading the data from before that point. Refer to the instructions here: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-10-06 15:58:01] |
Both corrected the issue Thank you |
