Date/Time: Thu, 04 Jun 2026 14:02:37 +0000
loss connexion
View Count: 677
[2022-09-29 21:17:03]
User591166 - Posts: 9
hello
I encounter the following problem with my status bar:
if I activate 'file > disconnect', the bar turns red
and if I activate 'file > connect to datafeed' it goes back to green.
on the other hand, if I cut my network access, the loss of connection is well recorded at the level of the sierra logs:
SC Data - All Services | Disconnected from the server. | 2022-09-29 22:57:13.986
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-09-29 22:57:13.986
DTC Client socket (1) | Closed. | 2022-09-29 22:57:13.986
but the status bar does not react and remains green.
I did not find any reference in the sierra docs nor in the FAQ to deal with this problem.
I also tried to look for the doc on the functionality
window > server status monitoring window
without success.
Thanks for your help
[2022-09-30 00:35:02]
Sierra_Chart Engineering - Posts: 23928
What you see does make sense. The market data connections in many cases work in the background and do not affect the main data feed status.
Full documentation for the Status Bar is here:
Status Bar
Date Time Of Last Edit: 2022-09-30 09:18:41
[2022-09-30 17:39:37]
User90125 - Posts: 715
Support,
Can sc.ServerConnectionState be updated to include these background connections?
Or perhaps a secondary ASCIL variable called sc.BackgroundServerConnectionState could be added?
Thanks.
[2022-10-01 09:02:15]
No, that is far too involved. And there are multiple connections, more than just one depending upon the symbols being used.
There would have to be a separate variable for each connection. It is just too involved for us to be spending time on. It is not something we would do.
