Date/Time: Fri, 02 Oct 2026 08:54:48 +0000
change orders depth on DOM
View Count: 754
| [2022-09-28 15:14:40] |
| User449884 - Posts: 229 |
How do i change market depth on the DOM? Id like to see further up and down. im on ver 2393 with CQG thanks |
| [2022-09-28 17:22:58] |
| John - SC Support - Posts: 48086 |
First refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels But chances are that if you are getting more than 1 level then you are probably getting all the levels that are being made available by CQG. In which case, your solution would be to use our Denali Exchange Data Feed in which there are 1400 levels available. Refer to the information here: Denali Exchange Data Feed: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-28 18:03:49] |
I do have the denali feed with MBO
| [2022-09-28 21:10:39] |
The CME Group exchange that you had active did not renew on September 1, 2022 due to a lack of funds in your account at that time. Therefore, you have not had any real-time Denali data for the month of September. You can reactivate the exchange(s) that you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges You may want to wait until October 1, 2022 to reactivate the exchange, as the exchanges are not pro-rated, so if you activate the exchange today (September 28, 2022) you will pay the full amount for the remaining 2 days of September and then pay again on October 1 for October. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
