Date/Time: Mon, 06 May 2024 01:13:29 +0000
[User Discussion] - Linear Regressive Slope based on CCI (possible bug)
View Count: 2303
[2013-04-29 21:08:05] |
Motig - Posts: 2 |
Steps to reproduce: - insert two studies into a chart: Linear Regressive Slope (LRS) + Commodity Index Channel (CCI). Insert them into different chart regions. - Go to "Settings" -> "Settings and Inputs" tab of the LRS study - Change "Based on" from <Main price graph> to the CCI you inserted and set "Input Data" to the "CCI". Confirm. See the scale and the values of LRS. These should oscillate between -1 to 1 but instead they oscillate in values typical for CCI. If you change "Based on" to the <Main price graph> in LRS, the values are correct, oscillating between -1 to 1. Is it a bug or am I doing something wrong? I tried to help myself by changing the scale of the LRS study but nothing helped. |
[2013-04-29 21:18:59] |
Looks OK for us: http://www.sierrachart.com/image.php?l=1367270320184.png The bottom graph is based upon the Commodity Channel Index. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-30 06:42:32] |
Motig - Posts: 2 |
But look at the scale, at the values of the bottom LRS. On the picture you posted, see the scale of the bottom LRS - I see there are values 20, 0 and -20 ...but that doesn't make sense, I'm expecting a scale with values similar to the first LRS on the picture (in which the scale is from -0.4 to 0.4). Linear Regressive Slope: LRS: 26.6 (CCI, 10) ---> The actual value of the last LRS on the picture is 26.6 ...that is too much. LRS with such value represent a dramatically steep slope. Such steepness would exist only if there were great jumps in CCI values, but there are none. Date Time Of Last Edit: 2013-04-30 06:43:37
