Date/Time: Tue, 04 Nov 2025 13:48:51 +0000
Scalping DOM emergency stop only possible?
View Count: 787
|   [2022-09-26 18:37:25]     |
| Woodzy - Posts: 35 |
                When scalping the DOM I want quick in and out not messing around moving OCO or attached orders, but rather doing it all manually just using the bid & offer columns.  Currently I do not use any attached orders, but I would prefer to enter trade with an emergency stop in place and have this automatically cancel when position is flat.  I don’t want to use the Trade flatten and cancel button to close trades because I’m trying to pick my price on the DOM.   Also if I attach a stop to my trade then when I go to close out the trade using either the bid or ask column, another stop is placed and I’m left with 2 active stops one above and one below price. I’ve attached an image to help explain what I mean, but I don't think what I'm asking for is possible, thanks  |
|   [2022-09-27 09:36:32]     |
| Sierra_Chart Engineering - Posts: 21299 |
                You will want to use Attached Orders and configure it for a single stop only (This will be the emergency stop): Attached Orders: Step-By-Step Instructions Enable the Scale Out option: Attached Orders: Scaling Out Enable this option: Basic Trading and the Trade Window: Main/C >> Menu >> Orders >> Cancel Orders on Flat Position (chart specific) All of the above will accomplish what you want. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
