Date/Time: Tue, 18 Mar 2025 13:40:55 +0000
PnL in Spreadsheet differs from Trading Window
View Count: 779
[2022-09-20 18:46:48] |
Jupitersbay - Posts: 54 |
Hi there, I just can`t figure out, why the PnL in the TradeWindow is different from that in the spreadsheet cell J10. I'd like to use it for the Exits of the trade. Thank you |
[2022-09-20 21:12:53] |
John - SC Support - Posts: 38735 |
The information in J10 corresponds to the P/L that is displayed on the Trade Window. The difference is that what is displayed in the Trade Window is controlled by the Chart Settings for the Profit/Loss Display. Whereas the Spreadsheet is always displaying currency. Therefore, the connection in the image you provided is that the P/L is showing 50 Ticks of profit (50T). For the ES the Currency Value per Tick is 12.5, therefore what is shown in the Spreadsheet is 50 * 12.5 = 625. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-20 21:28:33] |
OMG. That was simple. Obvious with these numbers... Danke schön. |
