Date/Time: Sun, 27 Sep 2026 17:36:03 +0000
Create more than one Simulation Trade Account
View Count: 4671
[2022-09-14 07:07:36]
User629706 - Posts: 1
I am trying to create additional trade simulation accounts. I was able to create one Trade Simulation Account only.
Here is what I did so far:
* I Specified 5 allowed trades simulation accounts (see screenshot) as per this documentation:
Newer versions of Sierra Chart supports multiple Trade Simulation Accounts.
The number of trade simulation accounts is set through Global Settings >> General Trade Settings >> Number Simulation Accounts. Specify a number between 1 to 400.
Trade Simulation: Multiple Trade Simulation Accounts
* I then followed these instructions:
Select Trade >> Trade Accounts Monitor.
Select Manage >> New Trade Account.
In the Trade Account edit field enter any trade account identifier which is at least three characters. Using letters and numbers only.
Simulated Futures Trading Service
However, in my Trade account monitor, most of my buttons have been greyed out. (screenshot attached) I created the simulation account in my trial period. Then once I paid up for the signed service the functionality seems unavailable.
Please advise
imageGeneral trade settings.jpg / V - Attached On 2022-09-14 07:06:13 UTC - Size: 152.51 KB - 363 views
imageTrade Account Monitor.jpg / V - Attached On 2022-09-14 07:06:18 UTC - Size: 66.29 KB - 369 views
[2022-09-14 07:30:31]
Sierra_Chart Engineering - Posts: 24992
Follow the instructions here to set Sierra Chart to use the Trading Evaluator service:
Simulated Futures Trading Service: Setup Instructions
Only then can you create accounts through that service.
The information here is not applicable when using the Trading Evaluator service:
[2024-07-16 01:01:17]
Mitch1840 - Posts: 20
Two questions:
1. How do I get trade menu on the left side when I right click instead of listing in one side of the menu. I want to have it on left side along with my right click menu. Currently its at the bottom and I have to select it to go for sub menu to trade. I want it on same menu where I can select buy and sell with out an extra step.
2. In the copy trade function how can I save my setup where I don't have to enable every time I take a trade and it saves my preferences for the copy trade window/function. ?
Basically My order allocation is saved so I don't have to enable it every time I take a trade.
imageLeftClick .png / V - Attached On 2024-07-16 00:59:24 UTC - Size: 19.01 KB - 247 views
imageOrder Allocation .png / V - Attached On 2024-07-16 00:59:36 UTC - Size: 28.98 KB - 271 views
[2024-07-16 15:43:53]
John - SC Support - Posts: 48028
1. Refer to the following:
Global Trade Settings Windows: Display Chart Trade Commands As Sub-Menu (Global Settings >> Chart Trade Settings >> General >> Order Entry)
2. You have the "Order Allocation" set to be included with "Linking" and "Trade Window Configurations". As such, if you have not specifically saved a setup with all your order configurations and with all the charts that have the Trade Window setup, then when you make changes the Order Allocations will be adjusted based on those other settings.
If you want an Order Allocation to stay static for a particular chart and trade configuration, then set both of those options to "No". Then the order allocation for that chart will always be the same.
Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Linking
