Date/Time: Mon, 17 Mar 2025 18:25:48 +0000
Binance Data download problem
View Count: 938
[2022-09-12 22:06:48]
User343060 - Posts: 7
When i try to download data for the symbol BTCUSDT_PERP_BINANCE from an existing chart, i have a problem, it is blocked at 0% ( i tryed with multiple existing charts, i have the same problem)
But when i open a new chart for the same symbol, it works
How do i resolve this problem ?
image2022-09-13 00_02_05-Mail.png / V - Attached On 2022-09-12 22:05:56 UTC - Size: 15.01 KB - 98 views
image2022-09-13 00_02_19-Mail.png / V - Attached On 2022-09-12 22:06:07 UTC - Size: 49.89 KB - 104 views
[2022-09-13 08:55:14]
Sierra_Chart Engineering - Posts: 18809
This is a data loading problem from the local data file. Not a problem with downloading historical data.
The problem is most likely what is described here:
Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols
You need to create a new chart and adjust the chart settings as explained. You cannot use an existing Chartbook if you are having this problem.
Date Time Of Last Edit: 2022-09-13 08:55:22
