Date/Time: Tue, 04 Nov 2025 16:32:28 +0000
free 15 days activation error
View Count: 438
| [2022-09-12 05:23:18] |
| dhaval bamnelkar - Posts: 2 |
i am trying to activate my free trial but there is an issue in platform I put my number code came on my number but when it put code its showing that number not verified and when I tried again I put my number again then its showing me that number is verified but I am not able to start my trial. |
| [2022-09-12 08:51:48] |
| Sierra_Chart Engineering - Posts: 21306 |
Your trial actually is active. Restart Sierra Chart following these instructions: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
