Date/Time: Fri, 31 Jul 2026 20:13:26 +0000
Time scale across bottom on chart
View Count: 1333
[2022-09-07 16:32:06]
Kellie Lacey - Posts: 79
Hi, can someone please let me know where I can change the time scale across the bottom of my charts so it's not in 10 minute increments? thanks
[2022-09-07 17:26:12]
thanks, also I am having real trouble trying to scroll on my charts, I went to the studies part to change in there but I would really appreciate it if when someone has time to connect with me remotely so I can show exactly what I am trying to do, could someone please let me know if this will be possible? many thanks
[2022-09-08 00:46:03]
John - SC Support - Posts: 47421
The time scale adjusts in order to best show the times based on the bar spacing that is set. Therefore, the only way to get a specific timing is to adjust the bar spacing until you get what you want.
Unfortunately, we only do remote support for when there is a problem that we need to see on someone's system that we can not determine the problem through this forum.
We do recommend using Diana Pena as an independent consultant that helps people with Sierra Chart. You can contact her here:
https://bio.link/dianapena
[2022-09-08 07:33:31]
Ok thanks John, I just want to be able to scroll using my mouse to the left and right of my charts and up and down but it seems you can only do one or the other is that right?
[2022-09-08 16:00:27]
Refer to the options for the Scroll Wheel here:
General Settings Window: Scroll Wheel (Global Settings >> General Settings >> GUI >> Scroll)
Just so you are aware, you can also use the Hand tool and click and drag the chart and move it in all directions. Though you have to enable the following setting in order to allow the Hand tool to move up/down:
Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options)
[2022-09-08 19:36:57]
many thanks that's helpful, is there a way of being able to do that and also move the chart up and down, as it seems to allow me to use the hand tool to move left and right but not up and down? thanks
[2022-09-08 20:38:30]
Refer to the setting we referenced above for the Hand Tool to allow vertical movement.
[2022-09-09 07:25:46]
Hi yes I did that and it only moves chart left to right, not to worry I'll try an figure it out thanks
