Date/Time: Mon, 17 Mar 2025 18:25:47 +0000
Connected but no data/information showing past my last trading session on 9/01/22
View Count: 1591
[2022-09-06 16:15:14]
User757136 - Posts: 2
Hello - I last traded on 9/01/22. Today I opened SC and it loaded all of my charts to the moment I logged off previously, 2022-09-01 11:38:46. From that point on no information exits in my charts. Quote boards show "0" for values on all CME/NYMEX/CBOT contracts. Time & Sales windows are empty. DOMs do not show anything, as if it is the weekend. Also the [M] that would normally appear to signify Denali data is not showing on any chart. I am effectively disconnected and unable to operate. Please help.
[2022-09-06 16:40:31]
User810254 - Posts: 4
Same here! CANNOT perform a successful "Download Data from End of Chart" operation for VVIX-IND-CBOE, VIX-IND-CBOE, VXN-IND-CBOE, RVX-IND-CBOE, etc... Last effective record: 8/30/2022, nothing afterwards.
What is going on? Checked definitions on IB side (Trader Workstation) and are still the same, as always, and I can also see historical records, there!
[2022-09-06 22:46:12]
John - SC Support - Posts: 38711
User757136:
If you are still having an issue, then we need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-09-06 22:47:00]
User810254:
You are using Interactive Brokers data, so we can not say what is occurring. We do not give support for IB data.
[2022-09-06 23:48:55]
User810254:
This does not make much sense to me, nor it really helps me. I have been downloading historical data for those symbols for a LONG time, until just now. My current trading-desk (based on Sierra) is now rendered INOPERABLE, and this is serious.
Since WHEN IB-data is not supported?
What do I need to do to get CBOE indexes (VVIX, VIX, VXN and RVX, historical and real-time) working properly again on Sierra?
What do I need to do to get SPY-STK-SMART/ARCA-USD, UVXY-STK-BATS, FXI-STK-SMART/ARCA-USD, SLV-STK-SMART/ARCA-USD working again on Sierra?
Thanks, in advance, for your valuable and prompt support!
This is what I see in my message log (VIX example):
Interactive Brokers | Using primary service for historical data for VIX-IND-CBOE | 2022-09-06 19:33:45.628
Added historical Daily data request for VIX-IND-CBOE to the queue. | 2022-09-06 19:33:45.628
Triggering next historical data download in queue. | 2022-09-06 19:33:45.628
HD Request # 69 | Downloading Historical Daily chart data for VIX-IND-CBOE. Starting date: 2022-08-26. Service: interactive_brokers.trading | 2022-09-06 19:33:45.630
HD Request # 69 | Requesting 21 days of historical Daily data for VIX-IND-CBOE with end date 2022-09-16 | 2022-09-06 19:33:45.630
HD Request # 69 | Message from IB: End Date/Time: The date, time, or time-zone entered is invalid. The correct format is yyyymmdd hh:mm:ss xxx where yyyymmdd and xxx are optional. E.g.: 20031126 15:59:00 US/Eastern Note that there is a space between the date and time, and between the time and time-zone. If no date is specified, current date is assumed. If no time-zone is specified, local time-zone is assumed(deprecated). You can also provide yyyymmddd-hh:mm:ss time is in UTC. Note that there is a dash between the date and time in UTC notation. IB Error Code: 10314. Request ID: 200028. | 2022-09-06 19:33:45.693
HD Request # 69 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VIX-IND-CBOE | 2022-09-06 19:33:45.693
HD Request # 69 | Completion time: 0s. | 2022-09-06 19:33:45.693
HD Request # 69 | Daily data download complete for VIX-IND-CBOE. Unique request ID: 83 | 2022-09-06 19:33:45.693
Removing historical data download ID 83. | 2022-09-06 19:33:45.693
Date Time Of Last Edit: 2022-09-06 23:50:27
[2022-09-07 03:30:11]
Leif - Posts: 9
I am experiencing same issue. My Forex data has big gaps now ... this is quite a serious problem. I get same "date, time or time zone entered is invalid" message. What do you suggest?
[2022-09-07 08:41:04]
Sierra_Chart Engineering - Posts: 18809
There are different issues being reported in this thread from different users.
Regarding historical data from Interactive Brokers, apparently they have made a change which is causing a problem. We are working on resolving the problem now. Just give us about an hour or two for a new release.
[2022-09-07 16:59:29]
We have put out a fix for the Interactive Brokers historical data issue. Update to the Pre-Release to get this change.
[2022-09-14 22:25:12]
Just wanted to send a quick thank-you response for the pre-release load.
After plenty of testing and real-time work, it has corrected the missing historical data when being sourced from IB, indeed.
THANK YOU!
Date Time Of Last Edit: 2022-09-14 22:25:52
