Date/Time: Mon, 17 Mar 2025 01:21:24 +0000
sierra wont open chartbook and stay connected
View Count: 363
[2022-09-01 18:30:13]
User163689 - Posts: 29
Using version 2431 and when i open chartbook it will start to download and open chartbook but then disconnects and reconnects its been doing this for 3 hours says not responding
[2022-09-01 18:34:39]
Sierra_Chart Engineering - Posts: 18801
First thing to do is to not use that Chartbook.
Start with a new Chartbook and a minimal number of charts. See if you still have a problem with losing the connection to the data feed.
Also run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
Date Time Of Last Edit: 2022-09-01 18:35:28
[2022-09-01 18:47:56]
Also refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
