Date/Time: Sun, 24 Nov 2024 09:24:20 +0000
Connected to Data Feed but not seeing any data
View Count: 498
[2022-09-01 01:17:22]
User643426 - Posts: 127
I'm connected to the data feed and have sufficient funds in my account but I'm not seeing any data. Could you please tell me why?
[2022-09-01 16:20:27]
Everything on your account looks good.
The first thing we want you to do is to select Edit >> Translate Symbols to Current Service to ensure that you have the correct symbols for the trading service you have selected.
If that does not work, then we need to see your message log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2024-06-07 20:47:22]
Hi John,
I have Teton order routing and would like Sierra Chart to place a 20% limit loss on my accounts. I know there is the Global Profit/Loss Management feature where you can set a Daily Net Loss amount but that can be disabled. I would greatly appreciate if Sierra Chart/Teton Order Routing would place a 20% limit loss on my account so that when it is hit, I can no longer trade for the day. Thank you.
[2024-06-07 21:19:53]
You need to check with your broker to see if they can do this for you.
[2024-06-07 21:22:20]
My broker won't do it. Can Sierra Chart please do it for me?
[2024-06-07 21:22:59]
I will pay a fee if needed. It is very important for me to have that.
[2024-06-07 21:35:57]
As we stated in the other thread - this is not something we can do. The control over this is with the brokers, and it is their choice to implement it or not.
I am sorry that there is nothing we can do for this.
[2024-06-07 22:31:18]
Sierra_Chart Engineering - Posts: 17154
You are able to control this with Teton order routing but not as a percentage but a fixed amount:
Who is your broker?
