Date/Time: Mon, 17 Mar 2025 01:10:25 +0000
Denali exchange data feed is not renewing
View Count: 309
[2022-09-01 00:02:22] |
User447431 - Posts: 29 |
Hi.. I subscribed for "CME with Market Depth for nonprofessional Trading accounts" ~11 usd/month but im not receiving the data feed, tried to click on Deactivate then Activate but didnt work.. sierra chart is updated to last version, what should I do?
[2022-09-01 00:32:55] |
John - SC Support - Posts: 38678 |
Everything on your account looks good, so there is nothing there for which you would not be getting the real-time data. Please follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
