Date/Time: Tue, 22 Apr 2025 10:26:15 +0000
Unable to use/see complete Chartbook on Laptop versus Desktop
View Count: 565
[2022-08-26 00:05:41]
User643426 - Posts: 136
I'm not able to use or view the complete chartbook I created on a Desktop computer, on my Laptop. Are there any ways to improve usability of Sierra Chartbooks and Dom on a Laptop computer?
[2022-08-26 00:39:59]
ForgivingComputers.com - Posts: 1042
Are both systems running the same version of Sierra Chart?
[2022-08-26 11:21:09]
Sierra_Chart Engineering - Posts: 19305
First are all of the chart windows listed under the CW menu on your laptop?
[2022-08-26 13:57:01]
JohnR - User831573 - Posts: 330
My guess is that the resolution of your desktop monitor is different (greater) than the laptop. This would not be a SC issue, as it will happen with all apps. I believe, when SC saves a chartbook, it saves each windows locations. If you your laptop does not have the ability to go to that high of a resolution, then part or even all of a chart will be off your display.
Here is one URL that shows how to 'find / get back" missing windows (charts)
https://www.howtogeek.com/howto/windows/bring-misplaced-off-screen-windows-back-to-your-desktop-keyboard-trick/
Hope this helps,
JohnR
[2023-03-09 12:06:31]
User21339 - Posts: 61
I eventually got all fonts at a good size [for me] on the dual monitor setup which is a resolution of 2560x1440 scaling to 125%
when i install onto laptop which is 3840x2160 and recommended scaling of 300% the font in the watchlist is too small to read.
Ive adjusted all the other fonts to suit this resolution.
I have the watchlist on the control bar.
How can i change the font size on that?
