Date/Time: Tue, 04 Nov 2025 12:43:36 +0000
GC charts stuck on 8/15
View Count: 1495
[2022-09-08 16:43:31]
Thaddeus Fulmer - Posts: 71
Ah, just seeing your replies. been away from my email. That's Awesome!!! It seems to have worked. I don't really know if I should take this step or not: Update/Apply Symbol Settings to Charts. Everything seems fine without having done that.
Thanks for getting back to me and reading my over-explanations.
[2022-09-08 18:07:12]
John - SC Support - Posts: 42737
You do not need to select the option for "Update/Apply Symbol Settings to Charts". That would only be needed if you changed something like the Session Times and wanted to then apply those new session times to the charts of that symbol.
