Date/Time: Mon, 25 Nov 2024 06:52:28 +0000
Denali vs Rithmic volume profile discrepancies?
View Count: 926
[2022-08-23 03:50:51] |
User280673 - Posts: 27 |
Hi, I am really enjoying the software thus far. However, I am experiencing some differences between Rithmic vs denali volume profile. I know Rithmic is touted as one of the best data feeds by many traders. So I am using it as a benchmark (which may be an inaccurate assumption). For example, on 8/8 POC for Denali was 4143 whereas Rithmic was showing 4141.5. I have it set to 1 tick, ticks per volume bar as 1, etc. to ensure I get the most accurate data. However, I am still seeing these slight discrepancies. It is not a huge deal, but I want to get to the bottom of it if I am doing something wrong on my end. Please let me know if there is anything to be done. I know that denali is directly from the CME so it is surprising that I am seeing these discrepancies which lead me to believe I may be doing something wrong. |
[2022-08-23 04:25:57] |
Sierra_Chart Engineering - Posts: 17172 |
If this is not done already, set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration To make sure there is no missing data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. So I am using it as a benchmark (which may be an inaccurate assumption). No you cannot do that. The Denali Data Feed in regards to data is perfect.When it comes to a point of control calculation what counts, is complete historical data and with the Denali Data Feed that is going to be perfect in that regard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-19 11:18:41] |
cesium - Posts: 85 |
Hello, How can I verify the accuracy of my rithmic data using denali? When I switch to teton/denali, sierrachart asks if I would like to translate the symbol. However when i check file explorer there seems to be a new scid file. When i switch to teton and hit apply, is sierrachart downloading tick data from you? Just want to make sure im covering my bases Thank you edit: using 1 tick renko and loaded rithmic data feed i can visibly see renko bars here and there missing on 2024-03-13. I have deleted and redownloaded data 2 times now additionally with an application restart and the issue persists. is this an issue with rithmic as usual? thank you edit more issues: when i switch to teton, and select delete and redownload, i get no response from sierrachart sorry for multiple edits Date Time Of Last Edit: 2024-03-19 12:22:08
[2024-03-19 12:56:16] |
For help with missing data, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart What exactly do you mean by this: i get no response from sierrachart
[2024-03-19 13:03:52] |
hello thank you, i right clicked and redownloaded, and i still see missing renko bars and on drawn volume profile, VPOC is not correct What i mean by I get no response, is that when connected to teton, I dont see sierrachart redownload data, and I see no new entries in the message log Date Time Of Last Edit: 2024-03-19 13:22:21
[2024-03-19 15:12:09] |
update: per Required Update to Current Version of Sierra Chart for Rithmic Users updating to v2619 fixed the issue thank you guys will keep sierrachart fully updated next time |
[2024-03-20 00:25:41] |
Ok this is good but we are not sure why the update would have resolved this. In the case of Teton order routing just make sure you are using the correct symbols: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-20 00:25:52
