Date/Time: Thu, 02 May 2024 09:21:17 +0000
Charts
View Count: 1686
[2013-04-29 11:24:22] |
User35208 - Posts: 12 |
It used to be that I can convert a daily chart to intraday chart by changing the time-frame via Chart Settings. However, v960 and above will not let me do so. Hopefully this is not an intended and permanent change because having such charting flexibility is very convenient.
[2013-04-29 16:17:31] |
This has been resolved. Please update by selecting Help >> Download Prerelease. You can also change the timeframe per bar using various other methods which are documented here: http://www.sierrachart.com/index.php?l=doc/doc_KeyboardCommands.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-29 16:21:50
