Date/Time: Sun, 16 Mar 2025 08:33:47 +0000
fisher transform study
View Count: 583
[2022-08-15 15:57:07]
User411320 - Posts: 303
hello,
at times the study will cross and then uncross, is this normal? if not, how can it be fixed
Date Time Of Last Edit: 2022-08-15 15:57:22
[2022-08-15 16:22:12]
John - SC Support - Posts: 38678
You need to understand what you are viewing. The blue line (Fisher Transform Offset) is the same data as the red line (Fisher Transform) only offset by 1 bar. So yes, it is normal that these lines would cross like they do. Refer to the information for the Fisher Transform at the following link (in particular, the last paragraph in the description):
Fisher Transform
If you do not want to see the offset then turn that subgraph off by setting the Draw Type to Ignore. Refer to the following:
Chart Studies: Ignore (ACSIL: DRAWSTYLE_IGNORE)
[2022-08-15 17:27:42]
what would happen if it was offset by more than 1 bar? curious
[2022-08-15 18:15:27]
You can always do this by using the Displacement option for the subgraph. Refer to the following:
Chart Studies: Subgraphs Tab >> Displacement
[2022-08-15 19:53:31]
so in this case the default of "0" displacement equals 1 bar offset, would "1"displacement equal 2 bar offset?
[2022-08-15 20:06:09]
Either 1 or -1. Off the top of our head we are not sure which one, as it depends on which way the bars are offset. Just test it and see.
[2022-08-15 20:15:40]
thanks
