Date/Time: Thu, 02 May 2024 06:00:39 +0000
Is there a daily high/low study that doesn't update past bars?
View Count: 1685
[2013-04-28 20:33:29] |
pe1111112 - Posts: 35 |
Is there a study that will show the high/low of the day but keep previous values as they were? On the attached image, the top chart is what I want, and the bottom chart is how the daily OHLC study works. I drew the line in the top study myself. Is there a study that does what I'm asking? Maybe I just missed it. This isn't high priority, I'm just curious. |
daily ohlc.png / V - Attached On 2013-04-28 20:32:51 UTC - Size: 27.22 KB - 592 views |
[2013-04-28 20:49:04] |
Use the Daily OHLC study and set the Graph High and Low Historically input to Yes.
[2013-04-28 21:08:08] |
edit - that worked, my mistake in the first reply. Thanks. Date Time Of Last Edit: 2013-04-28 21:09:18
