Date/Time: Sun, 16 Mar 2025 03:00:47 +0000
Says I'm a trial and don't have data flowing
View Count: 545
[2022-08-10 17:35:46] |
User404097 - Posts: 10 |
Hi - I am shut down for data flow completely. There is plenty of funds on the account. When I click "Reconnect Data" it says I am a "Trial User" and it can't reconnect. But I have been using SC for over a year. Sierra Chart: can someone please look at my account and help me reconnect. I need the account I have because we have a bunch of coding in it. Thanks - Ashley
[2022-08-10 18:57:16] |
John - SC Support - Posts: 38678 |
Everything on the account that you have posted from looks good. You should definitely not be getting anything that relates to a Trial account. The only reason that would occur is if you are logged in as a different user. Please check your Account Name by selecting "Help >> About" and ensure you are logged in with the correct account. Then please tell us (or give us a screenshot) exactly the wording of the message you are getting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-10 19:12:31] |
I checked in "Help - About" and it says I am the correct account. Correct UserName. My data is stopped at 8/05 at 1457. I don't have the message anymore to attach to you as I deleted it and tried to trouble shoot the problem. I've looked through the documentation and did all I could. Thanks for the help - ashley |
[2022-08-10 19:17:16] |
Please copy and paste your Message Log into this thread by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-10 19:26:46] |
Reading Internal Order ID file. | 2022-08-10 13:24:52.153 Reading Trade Orders file. | 2022-08-10 13:24:52.226 Reading Trade Positions file. | 2022-08-10 13:24:52.226 Reading Trade Account Data files. | 2022-08-10 13:24:52.226 Software version: 2394 64-bit | 2022-08-10 13:24:52.245 Primary Thread ID: 6296 | 2022-08-10 13:24:52.246 Usage end date: 2023-02-21 | 2022-08-10 13:24:52.246 Enabled for: Advanced Features 2. | 2022-08-10 13:24:52.246 Enabled for: Sierra Chart Historical Data Service. | 2022-08-10 13:24:52.246 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-08-10 13:24:52.246 Enabled for: Delayed Denali Exchange Data Feed. | 2022-08-10 13:24:52.246 Enabled for exchange2: CME | 2022-08-10 13:24:52.246 Enabled for exchange2: fairx_exchange.data | 2022-08-10 13:24:52.246 Enabled for exchange2: NASDAQ US stock data | 2022-08-10 13:24:52.246 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-08-10 13:24:52.246 Current selected Data/Trading service: SC Data - All Services | 2022-08-10 13:24:52.246 Custom symbol settings values: enabled | 2022-08-10 13:24:52.246 Chart Update Interval: 500 | 2022-08-10 13:24:52.246 Intraday Data Storage Time Unit: 0 | 2022-08-10 13:24:52.246 Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-08-10 13:24:52.246 2022-08-10 19:24:52 Local computer time in UTC | 2022-08-10 13:24:52.246 2022-08-10 13:24:52 Local computer time in SC Time Zone | 2022-08-10 13:24:52.246 2022-08-10 19:24:51 Server time in UTC | 2022-08-10 13:24:52.246 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-08-10 13:24:52.246 Program path: C:\SierraChart\ | 2022-08-10 13:24:52.246 Data Files path: C:\SierraChart\Data\ | 2022-08-10 13:24:52.246 OS Version Number: 10.0 | 2022-08-10 13:24:52.246 Locale Setting: C | 2022-08-10 13:24:52.246 DLLs: 3Contracts_TTE_LIVE_64.dll, 3Contracts_TTE_SIM_64.dll, OrderFlowLabs.com.beta_64.dll, OrderFlowLabs.com_64.dll, UserContributedStudies_64.dll | 2022-08-10 13:24:52.246 Allowed protected custom studies: OrderFlowLabs.com, OrderFlowLabs.com Beta | 2022-08-10 13:24:52.246 Crash reporter started: true | 2022-08-10 13:24:52.246 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2022-08-10 13:24:52.260 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-08-10 13:24:52.317 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-08-10 13:24:52.478 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-08-10 13:24:52.478 Received 5 login tokens. | 2022-08-10 13:24:52.774 Symbol settings MD5 received. Request ID: 1. | 2022-08-10 13:24:54.492 Symbol settings are up-to-date for scdataallservices. | 2022-08-10 13:24:54.492 Files to Open on Startup | Opening file: LIVE_TTE.cht | 2022-08-10 13:24:57.026 Loading DLL: C:\SierraChart\Data\OrderFlowLabs.com.dll (OrderFlowLabs.com_64.dll). Handle: 7ffb1ec90000 | 2022-08-10 13:24:57.039 Loading DLL: C:\SierraChart\Data\3Contracts_TTE_SIM.dll (3Contracts_TTE_SIM_64.dll). Handle: 66000000 | 2022-08-10 13:24:57.044 F.US.EPU22 3 Min #2 | Reloading chart. | 2022-08-10 13:24:57.189 F.US.EPU22 3 Min #1 | Reloading chart. | 2022-08-10 13:24:57.297 F.US.ENQU22 3 Min #8 | Reloading chart. | 2022-08-10 13:24:57.405 F.US.ENQU22 3 Min #9 | Reloading chart. | 2022-08-10 13:24:57.536 F.US.EPU22 500 Volume #4 | Reloading chart. | 2022-08-10 13:24:57.543 F.US.ENQU22 500 Volume #6 | Reloading chart. | 2022-08-10 13:24:57.550 F.US.EPU22 250 Volume #3 | Reloading chart. | 2022-08-10 13:24:57.566 Loading DLL: C:\SierraChart\Data\OrderFlowLabs.com.beta.dll (OrderFlowLabs.com.beta_64.dll). Handle: 7ffb1be40000 | 2022-08-10 13:24:57.569 F.US.EPU22 5000 Volume #5 | Reloading chart. | 2022-08-10 13:24:57.574 Using symbol data fast lookup vector | 2022-08-10 13:24:57.803 F.US.EPU22 3 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:24:58.818 F.US.ENQU22 3 Min #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:24:59.379 F.US.ENQU22 3 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:24:59.558 SC Data - All Services | Connected to server complete. | 2022-08-10 13:24:59.886 Triggering next historical data download in queue. | 2022-08-10 13:24:59.886 Triggering next historical data download in queue. | 2022-08-10 13:24:59.886 Triggering next historical data download in queue. | 2022-08-10 13:24:59.886 Triggering next historical data download in queue. | 2022-08-10 13:24:59.886 No download requests in the queue to start downloads for. | 2022-08-10 13:24:59.888 No download requests in the queue to start downloads for. | 2022-08-10 13:24:59.888 No download requests in the queue to start downloads for. | 2022-08-10 13:24:59.888 No download requests in the queue to start downloads for. | 2022-08-10 13:24:59.888 Using symbol data fast lookup vector | 2022-08-10 13:24:59.890 SC Data - All Services | Starting real-time market data updates for: F.US.EPU22. ID: 1 | 2022-08-10 13:24:59.890 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.EPU22 | 2022-08-10 13:24:59.890 SC Data - All Services | Requesting security definition data for: F.US.EPU22. ID: 1 | 2022-08-10 13:24:59.890 No historical data client is currently set to download historical Intraday data for F.US.EPU22. | 2022-08-10 13:24:59.890 Real-time Intraday chart data file updates started for F.US.EPU22 | 2022-08-10 13:24:59.890 Intraday chart data file opened for F.US.EPU22 | 2022-08-10 13:24:59.890 SC Data - All Services | Starting real-time market data updates for: F.US.ENQU22. ID: 2 | 2022-08-10 13:24:59.928 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.ENQU22 | 2022-08-10 13:24:59.928 SC Data - All Services | Requesting security definition data for: F.US.ENQU22. ID: 2 | 2022-08-10 13:24:59.928 No historical data client is currently set to download historical Intraday data for F.US.ENQU22. | 2022-08-10 13:24:59.928 Real-time Intraday chart data file updates started for F.US.ENQU22 | 2022-08-10 13:24:59.928 Intraday chart data file opened for F.US.ENQU22 | 2022-08-10 13:24:59.928 F.US.ENQU22 500 Volume #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:25:01.813 F.US.EPU22 3 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:25:04.922 F.US.EPU22 500 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:25:05.745 F.US.EPU22 250 Volume #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:25:05.949 F.US.EPU22 5000 Volume #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-10 13:25:12.657 |
[2022-08-10 20:32:05] |
The issue we see is that your symbols are not correct for the Current Selected Service. The service you have right now is "SC Data - All Services", but the symbols you have are for CQG. If you are going to stay connected to "SC Data - All Services" then you will need to open your Chartbooks and select "Edit >> Translate Symbols to Current Service". Or, if you are going to change your service to CQG, then you should be fine once you make that change. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
