Date/Time: Thu, 10 Sep 2026 20:05:35 +0000
T&S
View Count: 1605
| [2014-05-10 09:40:42] |
| bronson - Posts: 14 |
Hello , On ES i have doubts on my time and sales, I see no big order and if I compare (it) with an other one T&S on another platform, I see that a lot of information is missing. Which can be the probléme. I dont have filter size ,it's not the problem. My flow is the one marketed by sierra.I'm an infinity's custumer too( transact data) Regards. Date Time Of Last Edit: 2014-05-10 09:41:45
| [2014-05-10 20:11:44] |
Go to one of the charts that has the same symbol as the Time and Sales symbol and do you see in [M] indicator after the symbol? If so, then you are getting a complete tick by tick data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-05-11 05:26:57] |
What you can do to confirm you are receiving all the data is to go to Chart >> Chart Settings. Set the Days-Minutes-Seconds setting to 1-0-0. Let us know what the Start Time and End Time are set to. Add the Volume study to the chart. Look at the Volume value for the second to last bar in the chart and let us know what that is. One simple way to look at the second to last bar is to scroll the chart back by one bar and you will see the Volume displayed on the top line of the chart region for the volume. We will then confirm if the volume is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-11 05:28:56
| [2014-05-11 20:17:42] |
ES [M] from 2014-04-14 to 2014-05-09 from 00:00:00 to 23:59:00 time zone : Brussels ( +1CET/+2CEST) 2014-04-14 :1877840 2014-04-15 :2607803 --------16 :1641209 --------17 :1252898 --------21 :531351 --------22 :1106116 --------23 :995840 --------24 :1575525 --------25 :1506964 --------28 :2063715 --------29 :1218153 --------30 :1495506 2014-05-01 :934221 --------02 :1715304 --------05 :1175952 --------06 :1378404 --------07 :1995600 --------08 :1751706 --------09 :1475393 Regards . |
| [2014-05-12 00:30:58] |
This is the data direct from our server: [ID0] ESM4 1 Day #1 Formula Source Sheet #1. Enter and modify formulas for this sheet on Sheet1
Date Time [ID0.SG1] Open [ID0.SG2] High [ID0.SG3] Low [ID0.SG4] Last [ID0.SG5] Volume [ID0.SG6] # of Trades 2014-05-09 00:00:00 1870.25 1875.00 1862.50 1874.75 1475393 426142 2014-05-08 00:00:00 1874.75 1884.75 1865.00 1870.00 1751706 503633 2014-05-07 00:00:00 1864.00 1875.75 1854.50 1874.50 1995600 533614 2014-05-06 00:00:00 1877.50 1881.50 1861.75 1864.25 1378404 398589 2014-05-05 00:00:00 1875.50 1880.00 1860.50 1878.00 1175920 334217 2014-05-02 00:00:00 1878.75 1886.00 1872.00 1872.50 1715304 486530 2014-05-01 00:00:00 1879.50 1882.75 1871.50 1879.00 934221 252038 2014-04-30 00:00:00 1870.50 1880.25 1866.25 1879.25 1495506 433295 2014-04-29 00:00:00 1866.00 1875.25 1865.00 1870.50 1218153 374203 2014-04-28 00:00:00 1861.75 1871.75 1844.00 1866.25 2063715 574470 2014-04-25 00:00:00 1872.50 1873.75 1853.00 1860.25 1506964 439505 2014-04-24 00:00:00 1879.00 1882.50 1863.75 1873.00 1575525 454970 2014-04-23 00:00:00 1873.00 1880.75 1867.50 1880.25 995840 297082 2014-04-24 16:15:00 1867.50 1877.50 1861.00 1863.50 1383318 409166 2014-04-23 16:15:00 1869.50 1882.50 1863.75 1867.50 1309751 382547 2014-04-22 16:15:00 1873.50 1878.75 1867.50 1869.50 1065520 291114 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-12 00:31:07
| [2014-05-12 05:51:06] |
Thank you , i see that we have the same informations .That reassures me . So i don't understand why i don't have any order above 100 on my ES' s tape ! ^^ very strange . Best regards . |
| [2014-05-12 17:15:15] |
We do not watch the ES time and sales very closely. But generally we would not expect orders over 100 lots to be very common. But then again we do not watch this very closely. We assume that what other users might be doing is combining time and sales records which increases the volume per line displayed. There is an option for this in the Time and Sales Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
