Date/Time: Sun, 16 Mar 2025 00:02:53 +0000
Need help to set up chart settings like this
View Count: 353
[2022-08-02 17:43:32] |
User420706 - Posts: 1 |
I would like someone to tell me how to set up my chart like the one attached.
Date Time Of Last Edit: 2022-08-02 17:44:27
[2022-08-02 20:48:25] |
John - SC Support - Posts: 38678 |
To start, the main chart is a Numbers Bars study with 2 columns displayed. In the first column it looks like the information is the Ask Volume x Bid Volume and the Candlestick outline is displayed using the Open and Close Marker Style, refer to the following: Numbers Bars: Open and Close Marker Style The second column is some kind of delta, but we can not say which one exactly. And a Volume Profile for the Background Type. Refer to the following: Numbers Bars: Column # Background Type At the bottom is the Numbers Bars Calculated Values. Refer to the information starting here: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
