Date/Time: Mon, 17 Mar 2025 07:12:29 +0000
[Programming Help] - Live Trade Activity to a Readable File
View Count: 477
[2022-08-02 08:33:26]
User230940 - Posts: 121
is there a possibility to get the real time Trade Activity incl. SIM Trading into a readable Logfile ?
I would like to have to more or less the data which is written to TradeActivity Logs. But this Logs/File are not readable.
I don not need all of the data.
I would like to have Order Entry, Fill, Change. And the same bracket like stoploss and Target orders incl. Entryvalue, lotsize, time, Id, parentID and so on.
I had in mind to create a Study which is collecting this data and write this data simple to a file on each kind of activity.
Create a Order => write to file, Change of order => write 2 file, Filled of order => write file. Each action one line.
As it is displayed in the Trade Activity Viewer.
I get in contact with some professional SierraChart Coder, they said this is difficult and it is not really possible to get the whole lifecycle of a Order through a study.
What do you think? I there a way to get this kind of data in real time?
Maybe a API for the Trade Activity Log.
best regards
[2022-08-02 19:25:27]
John - SC Support - Posts: 38678
Take a look at the information on the following page for the items that are available through ACSIL related to orders and positions:
Automated Trading From an Advanced Custom Study
[2022-08-03 14:26:06]
a API or command line tool to export the trade activity from Tradeactivity Logs will not become available?
Regards
[2022-08-03 19:41:08]
Sierra_Chart Engineering - Posts: 18801
You can access all of that data through the DTC Protocol server in Sierra Chart. You can access the order fills and current orders. And it actually it is possible to pull the full order history as well but that is not documented.
Date Time Of Last Edit: 2022-08-03 19:41:22
[2022-08-07 11:59:41]
Is it possible to get SIM Data from DTC Protocol?
