Date/Time: Sat, 19 Sep 2026 22:59:25 +0000
ticker BTBT-NQTV NASDAQ missing data
View Count: 855
[2022-07-30 08:29:58]
User346098 - Posts: 50
I have opened a new sierra chart instance via file -> new instance
and there is now missing data from historical and intraday for ticker BTBT-NQTV
Date Range in File From ( 2020-08-07) ( intraday )
and from 2020-03-25 ( historical )
it supposed to be from 2018-03-20
thanks.
[2022-07-30 09:54:51]
with some google searches I found old ticker was DNJR , I need a database to derive old tickers from the current ticker, or atleast if you could combine tickers into the historical chart.
if not scanning using "Associated watch list" becomes broken since there is missing data ...
[2022-07-30 10:16:33]
What you can do is open a chart for DNJR-NQTV and obtain the data that you need.
Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
And then rename the chart data file for that symbol to BTBT-NQTV:
Chart Data and Chart Data Files: Renaming Chart Data Files
You will first need to delete the existing chart data file for BTBT-NQTV.
Date Time Of Last Edit: 2022-07-30 10:17:34
[2022-07-31 09:18:26]
There is an issue with ticker AACG-NQTV, its previous ticker was ATAI-NQTV, the problem is a different company took its place and started trading with the same ticker ATAI and now the data is merged,
previous company data ends on 2019-10-16 and the new company starts on date 2021-06-18
so now I can't rename ATAI to AACG because ATAI is already filled with data
I need to cut the data out from ATAI starting from 2021-06-18 to end of the chart before I can rename it to AACG
Thanks.
[2022-08-01 08:17:41]
One thing you can do is reduce the Days to Load setting in the chart to not see the older data:
Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load)
Date Time Of Last Edit: 2022-08-01 08:17:55
