Date/Time: Sat, 15 Mar 2025 08:01:00 +0000
[Programming Help] - version 1908
View Count: 468
[2022-07-22 18:35:17] |
User512854 - Posts: 24 |
hi please advice where to find the version 1908
[2022-07-22 18:41:22] |
John - SC Support - Posts: 38678 |
That version of Sierra Chart software is no longer available. The farthest back we have available is 2204. Refer to the instructions at the following link for how to install a specific version: Software Download: Full Control Rollback Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 19:00:36] |
i have only the dll i dont have the cpp file how i can open the dll using the 2204 version? |
[2022-07-22 19:54:23] |
You will have to contact the programmer of that study and see if they will update it for you, or give you the original C++ file(s). We are sorry that we do not have older versions available, but we have to continue to move forward. Keeping older versions creates multiple issues for everyone, therefore we will always have a cutoff point before which the software will simply not be available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 20:13:54] |
for next time what files i should ask my programmer to give me and save with me? to be on safe side
[2022-07-22 20:40:04] |
You would need the original source code. If you tell the programmer that you need "the source code such that you can build the DLL yourself" then they should know what to give you. Generally, what you should get would be a single .cpp file (C++ file having an extension of .cpp). But depending on how they did their code there could be multiple files. If it is a single file, then it is easiest to use the Remote Build option in Sierra Chart to create your DLL. Refer to the information here: How to Build an Advanced Custom Study from Source Code Building with multiple files would require that you build locally, which is more complicated. If this situation were to arise, then we would recommend finding another programmer that could help you with getting the program built. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
